ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Repairs/Mods Leakdown Test Procedure and Equipment
Author | Topic: Leakdown Test Procedure and Equipment |
normo |
posted 11-28-2009 11:49 AM ET (US)
I'm a back yard mechanic looking for a used 50-HP motor. Could someone explain how a leak down test is accomplished? [Tell about the] piston position, equipment needed, securing the crank so it doesn't rotate, [and so on]. Is there an affordable alternative to the $80 tool for assuring a proper seal at the plug port? How is the test done? How are the results interpreted? How [is percentage of] blowby determined? What does it mean? |
posted 11-30-2009 09:41 AM ET (US)
[Separated from another discussion.] |
Stevebaz |
posted 11-30-2009 12:30 PM ET (US)
Try This, http://www.motorcycleproject.com/motorcycle/text/leakdown.html |
seahorse |
posted 11-30-2009 10:34 PM ET (US)
http://www.carcraft.com/techarticles/116_0406_cylinder_leakdown_tester/ index.html |
number9 |
posted 12-01-2009 07:47 AM ET (US)
Looked for some info on the tests and testers for light aircraft since I have one in my box and never used it. The link below to the Continental Service Bulletin provides the best information. It also explains the difference between the static and dynamic seal check, even provides a tip for correcting a leaky valve. Most of the the other links don't mention the static check or that no static leakage is allowed. The aircraft testers vary the orifice size depending upon displacement rather than allowing different dynamic leakage rates. Explanation of test: Testers:
HarlemSgt |
posted 12-02-2009 07:42 PM ET (US)
A leak down tester measures how much air will leak past the rings. You must place the piston at TDC (top dead center). The tool will have two gauges, one for incoming pressure and one for how much pressure is in the cyl. You compare the two gauges and the difference. If you have imput pressure @ 100 psi and cyl pressure is 95 psi, that would be 5% leakage, which is very good. Anything over 15% is considered poor. It is more accurate way of testing the internal components. You can also test the valves on a 4-stroke engine and see if your problem is rings, intake or exhaust valve or blown head gasket. |
modenacart |
posted 12-02-2009 08:22 PM ET (US)
Depending on how much money you want to spend, you can get static leak testers that have mass flowmeters and don't require a delta pressure. This is the type we use at work. |
