ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Repairs/Mods Sacrificial Anode Replacement
Author | Topic: Sacrificial Anode Replacement |
JMARTIN |
posted 12-23-2009 07:13 PM ET (US)
When do motor zinc's need replacing? http://i34.photobucket.com/albums/d137/jmartin-/DSCF7534.jpg It does not wiggle. John |
Lil Whaler Lover |
posted 12-23-2009 08:16 PM ET (US)
If an anode is eroded half away it is time to replace it. This is the least expensive life insurance you can get for your equipment. |
Bella con23 |
posted 12-23-2009 10:04 PM ET (US)
Personally, I would replace that one. It's a gallon of oil to replace them. Joe |
high sierra |
posted 12-24-2009 12:08 PM ET (US)
JMARTIN, scrape it somewhat clean and replace it next time you need a waterpump. I believe you have to take off the lower unit on that model. (or is there a bolt thru.) high sierra |
Peter |
posted 12-24-2009 12:21 PM ET (US)
It is through bolted. That one looks like it has served its useful life. |
jimp |
posted 12-24-2009 03:10 PM ET (US)
If you trailer, like me, it might have years of life. Keep an eye on it. I check mine once or twice a week (when I wash down the boat in the front yard). If panicked, buy a spare. JimP |
posted 12-24-2009 03:18 PM ET (US)
I recommend you rely on the advice of your engine's manufacturer regarding sacrificial anode replacement. Here is an excerpt from the owner's manual of my new 2010 model year engine regarding sacrificial anodes, or anti-corrosion anodes as they are called therein: -- "Your outboard is equipped with one or more anodes that "IMPORTANT: NEVER paint the anode, its fasteners, or its Based on these recommendations, the anode: --should be replaced when it has decayed to two-thirds its original size The size and material composition of the anode influences its behavior in preventing galvanic corrosion. For those reasons it seems reasonable to use an OEM replacement in order to get the proper material composition, and to replace the anode when its size begins to decrease. It is also a good idea to periodically check the electrical connection of the anode to the engine block and to the battery negative terminal. Use an ohmmeter to measure from the anode surface to the battery negative terminal. There should be an extremely low resistance reading, less than 0.1-ohm. This indicates the anode is properly bonded to the battery negative terminal; we assume the battery negative is well-bonded to the engine block. |
JMARTIN |
posted 12-27-2009 02:52 PM ET (US)
The owners manual says to replace when it is 2/3rds gone, so I am good. You do need to drop the lower unit to replace it. The water pump was done in May 08 and only has 76 hours on it since then. Now the time that the anode has been in the water is a lot more with the amount of trolling and shrimp pot sitting that the boat does. Some times the motor sits at the dock lowered due to lack of dock space for days at a time. |
Peter |
posted 12-27-2009 05:04 PM ET (US)
That anode looks pretty porous. A new one looks solid. I bet that if you removed it and put it on a scale, its weight would be 2/3's of the weight of a new one. If that was my motor, I would replace the anode. |
high sierra |
posted 12-27-2009 06:41 PM ET (US)
I figured it was necessary to remove the lower unit to change them. Just bolt another smaller one on the top side of the cavitation plate . Some motors came that way. high sierra |
