posted 07-14-2010 11:55 AM ET (US)
fina, I have a 2000 Mercury 150-HP with carburetors that behaves similarly at times. A few observations, commments:1) Cranking for 10 to 15 minutes will probably smoke your starter motor... check to make sure it's not drawing too much current (that is, dropping the voltage to below 8V).
2) The main problem I had was a cheap primer bulb (Tempo) that didn't fill the carbs or wouldn't maintain fuel in the line. The importance of a good primer bulb has been discussed several times in this forum. I'm now a believer.
3) Check your fuel filter... similar issue. There's one under the cowl as well as the external spin-on filter/water separater.
4) My carbed Mercury seems to need fresh fuel to start and run smoothly. If your gas has been sitting for a while, you'll likely get hard starting and p-poor performance.
5) Check to make sure the little electric primer solenoid is connected and squirting gas like it should. Mine had a cracked hose with predictable results. In fact, check all the little hoses for cracked ends and so forth.
Good luck,
Loafer
