posted 10-27-2010 10:08 PM ET (US)
The term "Power Pack" is usually associated with OMC engines. On Mercury engines the spark ignition module is often called "the switch box."Electrical components can be very intermittent. They often change with temperature. It can be very difficult to diagnose a problem with an intermittent electrical component. You must be patient, and you have to be ready to test and diagnose the problem as soon as it occurs, as often these problems cure themselves after a short rest time.
If you are not a good mechanic or a good electrical diagnostician, it may be difficult for you to locate the source of the problem, and particularly so if it occurs only occasionally.
As far as beginning to replace components without really doing any diagnosis or testing, I recommend you start with the least expensive components first. Replace things that do not cost much. Work you way upward in costs. It would be very effective if you could isolate the problem to be either:
--confined to one cylinder, or
--affecting all cylinders
before you start your program of part replacement. If only one cylinder is affected, you will replace only parts associated with that cylinder. If all cylinders are affected, you will replace only components that affect all cylinders.
Given the price of outboard motor parts, it may be more cost effective and consume much less time to just take the motor to a good mechanic for diagnosis and repair, provided the motor can be consistently put into a no-start condition. If the no-start happens only once in a blue moon, the mechanic will not have much chance to find the problem
Also, for any outboard motor which has been running well and suddenly refuses to start, the first thing to check is the Safety Lanyard and Kill Switch.
Also, I do not understand at all your description of the starting problem, to wit:
quote:
"[The Mercury 90-HP two-cycle motor] would not turn over, but the starter was working well."
You need to be more precise in your description. If the electric starter motor is turning and the engine is not turning, this is a completely different problem than a Crank-but-no-Start problem. Try again to convey to us precisely what you mean about the starting situation. Precision in your description of the problem will also be very important if you hire a mechanic. You will need to tell him precisely what has happened so that he can begin his diagnosis on a proper basis.
