Topic: Applying Gel Coat Resin Over Epoxy
fishyarns |
posted 12-19-2010 08:55 PM ET (US)
I just finished a three-layer [WEST System] epoxy barrier coat to cover bad crazing. I'm hoping to [apply] gel [coat resin] over it, instead of using urethane or epoxy paint. I want to have the thickness of the gel coat for beach landing and hull scratches. West says it [is] okay to [apply gel coat resin] over [their] product. [I am] not sure if just washing the blush is enough. Or, [do] I need to sand before spraying? Has anyone seen the long-term effect of [application of gel coat resin] over epoxy? Has the crazing come back?
Jeff
posted 12-19-2010 09:36 PM ET (US)
Unless you grind the area of crazing all the way back to the fiberglass matte, the crazing will return no matter what is applied over it.Also, epoxy barrier coat is a base layer for protecting gel coat when storing a vessel in the water for extended periods of time. I would not recommend gel coating over epoxy barrier coat. A good bottom paint is all I would recommend putting over an epoxy barrier coating |
posted 12-19-2010 10:37 PM ET (US)
WEST System literature gives detailed instructions on preparing an epoxy surface to a top coat of gel coat resin. Follow their instructions and you should not have any problems with the gel coat resin failing to adhere to the epoxy surface. |
posted 12-19-2010 10:40 PM ET (US)
I have made several repairs with epoxy using WEST System epoxy, then applied polyester resin gel coat as a top coat. I have not had any problems with the gel coat resin losing adhesion to the epoxy. Some of the repairs have been in place for years. |
fishyarns
posted 12-20-2010 09:42 AM ET (US)
I will plan on putting a barrier coat on the bottom over the new gelcoat. I am hoping The epoxy barrier on the sides will slow the crazing down. I couldn't take the old gel off without damageing the mat layer and didn't want to reglass everything. thanks for your ideas. |
Blackduck
posted 12-20-2010 10:18 AM ET (US)
If you want to be sure the gel coat will bond to the epoxy, the only way to go is with a "tie coat", something like System Three, SB -112. Washing with soap and water only works sometimes, despite what West claims. |
ConB
posted 12-20-2010 11:39 AM ET (US)
What model and how old a boat are we talking about?Unless it's a real collectable, I'd paint it. Con |
modenacart
posted 12-20-2010 04:00 PM ET (US)
If you want the gel coat to look good, regel coating is going to be a lot more work then you most likely want to do. |
cc378
posted 12-21-2010 07:18 AM ET (US)
I used West Systems to repair some 4' x 2" gashes in my 1972 11' Whaler. I followed West Systems instructions for prep and applied Spectrum Gellcoat. It has been in place for 10 years with no issues. |
fishyarns
posted 12-21-2010 07:33 AM ET (US)
the 13 footer is a 1964 sport. I have already done more than i wanted to. I have a guy who will spray the gelcoat for a couple hundred and I will sand it only above the water line. I would consider selling the boat with an 01 yamaha 40, 4 stroke. Probably just finish the project and use it. |
modenacart
posted 12-21-2010 04:11 PM ET (US)
If you want it to look good, you will have many, many, many days of sanding. |
modenacart
posted 12-21-2010 04:12 PM ET (US)
If the surface is not prep properly, it will look wavy and you will see every low spot after polishing. This will be true of any polished finish. |
