posted 03-15-2011 12:13 PM ET (US)
Generally removing gas out of an inboard tank is a pain. I'd recommend one of two ways.The safest way is to connect a hose by the primer bulb and see if gravity will do its thing. Empty the gas into a container and all is ok.
Option two would be a specifically designed fuel pump (properly grounded etc) and connect it to the same area. That would get it out faster.
Extending the hose from the fuel water seperator would probably offer less restrictions making gravity work better.
Tom
P.S. If so equipped you could always drive the boat around until its empty and then have Seatow take you home. LOL
