| Author | Topic: Gelcoat "microdots" and how to get rid of them |
| Buckda |
I'm cleaning up the boat, doing some wetsanding and waxing, etc. to get her ready for the season. This is not a new phenomenon, I'm trying to address it. The whole boat was rather chalky, but the areas exposed to the sun (topsides) show little, tiny black or grey dots. This boat was neglected by the former owner - and I waxed it last year when I bought her, but didn't go much further to cut the oxidation on the topsides. Now I'm going through and doing some deep cleaning. I don't want to sand too much of the gelcoat off - and I'm hoping these microdots aren't indication that I have thinned the gelcoat too much...but these dots are present even before I begin sanding. I've been stepping up the sanding - starting with a course 400 grit, then to 600, 1,000 and 1,500, followed by a polish and wax. The finished area is butter smooth, but the dots remain. Any suggestions on 1) what these are (and are indicating) and 2) how to make them go away (short of re-shooting the topsides with new gelcoat). ?? Thanks in advance for your help. Dave |
| home Aside |
I've noticed those before, I had a few on my stern cross beam (if they were in fact the same thing you're talking about) I thought it might have been mildew in my case. I used 409 and a kitchen scrubby to clean the surface, it seems to have worked well. Pat |
| Blackduck |
Heck, just take a sharp object and scrape down one of the dots to see wether you are down to the laminate or not. Use a magnifier if your eyes are as weak as mine. I wouldn't abrade any more of the gel coat until you make this determination. |
| Buckda |
On further inspection, these are tiny pores in the gelcoat. The wax fills them so they are tiny "white dots" in those areas. |
| ConB |
I have had lots of mildew spots in the gel coat on a couple of old boats. Had to tilex the topsides before I would wax. Con |
| Buckda |
It is very unlikely that this is mildew. If it is, we're all in trouble because it's tenacious enough to withstand scrubbing, washing, wetsanding and orbital buffing. God help us. |
| davej14 |
How about this: |
| davej14 |
A better url for artillery fungus, it really is nasty stuff: http://www.firstchoicepowerwashing.com/artillery_fungus.html |
| Buckda |
Too big. Think angry (but detail-oriented) little elf with a pin and a small hammer. |
| Tom W Clark |
Those are just tiny little bubbles in the gel coat. Time, weather, sunlight UV and washing have exposed them and opened them up. Sanding more may just make them larger depending on how much of them is exposed now. I wouldn't worry about them too much. |
| ConB |
Try diluted beach on a small spot. If that does not fix it may be the gel coat is now to thin to polish. Con |
| Treypescatorie |
I concur with the bleach. I get the black specks all the time. I use bleach mixed with laundry soap, also use this solution on the non skid, works great. |
| pcrussell50 |
I'm pretty sure what Dave is talking about is what Tom described, and is not the little mold/mildew specks the rest of us get. From an old thread, many moons ago, I learned to use Barkeepers Friend for cleaning gelcoat, as its non-abrasive, cheap, and works like crazy. Takes off the mold specks like nobodys business. -Peter |
| PeteB88 |
Probably barnacle eggs. |
| Buckda |
Thanks Tom. I think that is exactly what I'm describing. Probably will need to wax more frequently? |
