Topic: 1981 90HP Mercury Outboard RPM hollow tube.....
rollingrightalong |
posted 05-12-2011 12:32 AM ET (US)
Whilst applying some heat to a stuck steering tube I singed the hollow tube, that's about 1/4" OD, that appears to run to the rpm guage on the console to the O/B. Is there any advice anywhere I can go to to see how to replace the hollow tube to the outboard (it seems to join the O/B at the lower leg and shaft junction and are there any sources for the tubing? Thanks in advance...
AZdave
posted 05-12-2011 02:44 AM ET (US)
I think this tube connects a tiny hole in the leading edge of the lower unit to a speedometer which runs on pressure. If you don't have that gauge the tube is of no concern. |
rollingrightalong
posted 05-12-2011 11:53 PM ET (US)
Thank you for the reply. My mistake, it does go to the speedometer. Any sources to buy replacement tubing (plastic 1/4") and any references on how to do the repair. Thank you, |
weekendwarrior
posted 05-13-2011 11:01 AM ET (US)
The local hardware store or pet store (think aquarium) should have some tube and a splice. Just replace the damaged portion by splicing in a new piece. |
