posted 07-11-2011 10:54 PM ET (US)
I need to install new white rubber window gaskets in my 1964 Eastport. I have the new gasket material and the windows out, and now I have a few questions:Is there any reason to put some kind of silicone caulking in the frames prior to putting in the glass? I don't know why I'd want to do that, but whomever had the glass out last put it back in with silicone caulk, with the rubber gasket on top of that. I'd think the white rubber gaskets would be sufficient to hold the glass in without help.
Is there some sort of trick I should employ in installing these gaskets? The rubber is very reluctant to go into its groove, and I can see a days-long wrestling match with this stuff.
Thanks in advance. Toby
