Topic: Nav Lights Not Working
Caribe |
posted 07-19-2011 03:12 PM ET (US)
My nav lights aren't working. Any advice? the toggle lights up but nothing is lit. Boat is a 16' Dauntless 2002. Thanks!
george170
posted 07-19-2011 03:38 PM ET (US)
Did you check to make sure the bulbs were good? The anchor light and the nav light both aren't working? Also you can check to see if there is a lose wire somewhere. A multimeter would help troubleshoot. |
Caribe
posted 07-19-2011 03:46 PM ET (US)
I'll double check. The problem is that both are out. There is a fuse on the panel. How do you reset? Thanks for your help. |
Dauntless_14_TX
posted 07-19-2011 04:20 PM ET (US)
If your switch lights up it can't be a fuse as a blown fuse would prevent any power to the switch. I'd go with looking for a loose wire on the back of the switch perhaps? If its not that I'd look into the switch itself and use a multimeter to see if the proper posts are getting 12V when the switch is in the "ON" position. If not its a bad switch. I have a 99' Dauntless 14 and just had to replace my NAV/ANC switch because it went bad. |
george170
posted 07-19-2011 09:23 PM ET (US)
You can also check the terminals on the switch for corrosion. |
