Topic: Mercury 150-HP Blackmax Starting and Acceleration Problems and Cure
coolarrow |
posted 10-04-2011 02:13 PM ET (US)
[A Mercury 150-HP Blackmax outboard engine is] having problems starting and stalling at 1,800-RPM. I changed the hoses and filter. When I hooked back up everything I noticed fuel running out of the motor and dripping down the inside of the transom. I took off the air intake cover and watched the gas pour out of the bottom right jet everytime [the engine] turns over. I know that the bottom two carburetors are where the choke operates. I have the engine level. I first thought I had a fuel restriction somewhere, however changing all the hoses and filter didn't make a difference. Any ideas?
L H G
posted 10-04-2011 03:51 PM ET (US)
Time to take it in for Mercury service. |
coolarrow
posted 10-04-2011 05:01 PM ET (US)
Well Larry, I was about to think you were right when I noticed that the spring on the throttle advance had popped out of that two-part arm where it bolts to the block. I took it apart, put it back together, and tightened that main bolt. Once again [the Mercury 150-HP Blackmax] runs like a kitten. That was a first. Too many bumpy roads in Mexico I guess! Runs perfect again |
