| Author | Topic: Making Minor Repairs With Polyester Resin |
What is the best polyester resin to use to make minor repairs to Boston Whaler boats? Please explain the technique in detail. I am approaching this problem from this basis: I bought a quart can of polyester resin and it included a small bottle marked catalyst. The only instructions I have are to add the catalyst to the resin before use. I need advice with plenty of details, and specific recommendations about brands and vendor. Please, you fans of epoxy, sit on your hands. Stay away from the keyboard. I want the polyester resin users to have no distractions. Thank you. |
| Binkster |
There is no set formula for the amount of catalyst to use. The warmer the temp. the less catalyst you need. don't use polyester resin below 60 degrees. It won't kick off. Maybe some will disagree with that statement, and just use more catalyst but the glass will be weak when it finally kicks off. In the summer here in Fl. I can use up a gallon of resin and have a half a bottle of catalyst left. I always mix up batches in small quantities. I experiment with the amount of catalyst so that I have about 15-20 minutes working time, and try to use the batch I mixed up in 10 minutes. That way you don't waste material and ruin your tools. Have a jar of lacquer thinner ready to drop your brush in and also some lacquer thinner in a tray, to put your other tools in too, while you are mixing up a new batch. Oh, another thing have a batch of latex gloves, you will have to keep changing them if you get resin on your hands which is inevitable. Figure out what you need for material and cut your mat, cloth, and or whatever you are using beforehand. Then set it out so you can just pick up the piece you need and glass it in and keep moving. Also some of the cheap resins will need to be sanded if they are kicked off before you add more glass, and some you can just keep on adding to, like if you don't finish in one day. What is your project anyway? |
My project is to apply some polyester resin to small areas of my Boston Whaler boat which have been repaired. I have attempted this a few times in the past, but my results were not very good. The polyester resin never hardened completely. I believe it was due to exposure to air. My understanding is that polyester resin will not cure to a hard surface if it is exposed to air. I need help in preparing polyester resin so when applied to the hull surface of a Boston Whaler boat the resin will cure to a hard surface finish. As I said, the only instructions I received when I bought my resin was to mix the whole can of resin with the entire bottle of catalyst. |
| L H G |
Brand: Evercoat #27 Vendor: almost any Marine store, including West Marine Catalyst ratio: 2% by volume. Cures in open air (don't confuse with polyester resin based Gelcoat which need s wax additive) Here is everything else you need to know. You can buy a half-pint and experiment! |
Larry--Thank you for the good advice. [I'll move more of the good advice about polyester resin use to this thread in the very near future.] |
| Jessielove |
Jim, It is my understanding that wax is used for the final coat only to promote a full cure. It then can be sanded and cleaned with acetone after a full cure. The only reason wax is added to the top/final coat is to seal the surface from air allowing a full cure. When fully cured it sands better (doesn't gum up the paper), has better adhesion ability when correctly prepped and better water proofing properties... This can be done a number of ways; I use gelcoat mixed with duratec additive (no wax), some people use gel mixed with wax, and others use the same resin they put the glass down with but with wax added for a 'cure coat'. As long as the laminating resin is able to be sealed from the air using any of these methods it should fully cure. So, I guess I am recommending you buy unwaxed resin and add your wax to the mix only for the final top coat.
The recommendation to add wax is appreciated, but you must tell me --what sort of wax --where one buys the wax --what proportions of wax to resin to use |
| wezie |
Mold Release Wax, on the shelf next to the polyester resins. Resins are sometimes labeled "finishing" and "laminating". Finishing will have wax, laminating will not. Note: Air-inhibited, is laminating resin. Confused? Welcome to my club. |
| ConB |
You could spray PVA (Polyvinyl alcohol) over the gelcoat before it cures and skip the wax. Con |
| andygere |
Skip all the wax additives and just buy poly resin with the liquid styrene wax already in it. It will be labeled as sanding resin or finishing resin. This will set up to a hard sandable finish. If you are laying up multiple layers of fiberglass cloth or mat, use laminating resin. This will remain tacky on the surface after curing. Don't make a simple process harder than it needs to be, just get the correct materials. |
| ConB |
Does any one know if Boston Whaler is using Vinyl Ester resin to build our boats with? Maybe this is the resin to use for repair. Con |
| L H G |
When you buy Spectrum gelcoat for your Whaler, in a liquid qt, it comes with both the catalyst and liquid wax, in small bottles. The required proportion is given on both bottles. If you buy Mini-Craft gelcoat for your Whaler, you can buy a premium grade that already has the wax in it. So I guess JimH has never purchased any Whaler recommended gelcoat or he would already know this? I believe the little paste containers alrealy have the wax in it also? I don't buy those. The Evercoat Formula #27 that I have recommended for underlying repairs does not need wax. |
ASIDE to Larry--I bought a small bottle of the Spectrum color-matched gel coat resin. The color match was terrible. I got a replacement bottle. I used a little bit of it. Before I could use the rest of the bottle the resin hardened in the bottle. This is one problem with polyester resins--they are slowly hardening in the bottle. The catalyst just speeds up the reaction. Short shelf life for the resin. You need to line up all the little repairs and do them all in a few days after you open the bottle of resin. |
| Binkster |
Con, this will clear everything up; |
| L H G |
Jim - the Spectrum paste patch kits are terrible, with zero shelf life. They are difficult to tint also. I buy the liquid gelcoat in qt or pint cans, and it lasts a long time. I now have two qts in a 'fridge, one Desert Tan, one Outrage Gray, and they are over a year old and are still good, easy to work with. Standard color matches are also terrible, particularly with the old Outrage Gray color. Not even close. I mix the two as needed for any exact color match I need, any boat. The liquid wax additive Spectrum includes with the liquid gelcoat is called "Spectrum Surface Seal" |
| Newtauk1 |
all answers here: http://www.fiberglasssupply.com/Product_Catalog/Polyester_Resins/ polyester_resins.html |
Larry--Good idea about the refrigerator for storage of resin. I used to keep my unexposed Kodak color film in the refrigerator. |
| RM NY |
what exactly are the repairs you are doing? Someone else already mentioned 2% by volume, this is your ratio. If its hot- try to keep it out of the sun but you are not supposed to deviate from this ratio too much. If its cold warm the surface and the resin a bit, you can add a little more MEKP but not too much, or in extreme situations you can use DMA ( N, N-Dimethylaniline) - but beware this is very disgusting and dangerous chemical to work with and store. The ratio is ridiculous to measure but it is used literally as a portion of a drop in a cup or a drop or two in a quart container. You mention putting a layer over the areas you are repairing- if you use a very thin coat it will have a tendency to be a little stickier then usual. You want a little bit of volume for that. If you are doing bodywork and gel coat over whatever you are using the resin on you don't want any TFA/wax ( tack free additive ) or PVA. I buy poly resin by the drum and never add wax to it when doing bodywork or gel coat work over it, this would actually be a bad thing to do for adhesion purposes. |
| andygere |
As others have mentioned, the Spectrum patch paste kits have lousy shelf life, but putting them in the refrigerator helps. I take it a step further, and seal the lid with a few wraps of electrical tape and put them in the freezer. It extends the life, though I can't pinpoint how long. When using the patch paste, I try to have as many repairs lined up and ready to go before ordering a kit, and I try to make all those repairs on a single day. It's expensive stuff, but it's easy to use and I've been able to get acceptable color matches when using it. Giving the repairs the full LHG style compound/polish/wax treatment really helps blend them in. I usually wait a week or two to ensure that the cure of the patch paste is complete. |
| Binkster |
[Changed topic to a different adhesive. Please, let's stick to topic: polyester resins or gel coat. Thanks--jimh] |
| crabby |
Pay attention to what Rob (RM NY) aka Raybo wrote above. He is one of the top east coast fiberglass repair guys (located on Long Island, NY) and knows what he is doing. It's rare that he pops into this forum but he is a regular on some of the more serious boat restoration forums. |
I am more confused than ever. Several people tell me to put all sorts of additives in the resin, then another--cited as a top expert--says don't put any additives. |
I am also confused by the citation of this information:
quote: That's from the link above to http://www.redrockstore.com/resin.htm Can someone explain why I want to use polyester resin in the first place? |
| L H G |
Jim - You'd best get your information from Boston Whaler, and a thousand other power boat builders, rather than some canoe store. But if you want to believe that garbage, you'd better be prepared for your Boston Whaler to disintigrate and sink one of these days. |
| Newtauk1 |
Wwhat is the purpose of this post? |
The purpose of this discussion is to elicit advice on using polyester resin. I am getting a lot of advice, but some of it is conflicting advice. As with any advice, I tend to give weight to the advice based on who is providing it. I trust L H G's advice, as I have seen his work first-hand and up-close. Other advice I will take under consideration. I am not interested in making comparisons to epoxy resin. That is an interesting topic, but it is not at all my interest here. I mentioned already, I have some small repairs on my boat that I would like to finish with polyester resin, and I am seeking advice. I have not had good results in the past. So I have elicited advice about using polyester resin. There are some previous discussions on this topic, but they tend to lack clear and concise details, including links to sources. For example, if someone recommends "adding wax," this is meaningless to me. I need to know what what what, what proportion, where to buy it, and how to handle it. This thread is progressing nicely. People who want to comment about the thread itself should sit on their hands and let us talk about polyester resin repair techniques. |
Regarding the wax, it has been recommended that "mold release wax" be used, and it is to be found on the shelf next to the resin. Do other concur? I thought mold release wax was a wax applied to the mold to inhibit the resin from bonding to the mold. I never heard that it was also used as an additive to the resin. Please let me have some more advice on this use of "mold release wax." Thanks. |
| Newtauk1 |
Getting advice on the internet via [discussion forums] makes no sense. |
| Owtrayj25 |
I think it's safe to say there are several types/brands of polyester resins out there, each with different nuances and application instructions. I think it would be helpful to know and understand: -What specific product you have previously attempted application, and what result was achieved -What specific instructions did you follow in your application Recommendations thus far cover several variations of polyester resin manufacturers, corresponding applications and installation instructions depending on the specific product. |
| Binkster |
Polyester resin is a honey colored resin with the consistency of thick paint or varnish. It is mixed with a catalyst, which turns it into a solid. It is never used by itself. It is used in conjuction with other fibergalss blanket like materials to form a shell like material. I realize this is a very simplitic explanation. The resin is never used by itself, say to fill screw holes. I believe jimh is aware of this. He then says he wants to use it like a bondo type material. Then folks chime in to give their advice no matter that they never had the pleasure of grinding glass in 90 degree summer heat, or watching on TV as some 'expert' does it. |
| Jessielove |
jimh The resins that are used in fiber reinforced composites can also be referred to as 'polymers'. Man-made polymers are generally called 'synthetic resins' or simply 'resins'. Polymers can be classified under two types, 'thermoplastic' and 'thermosetting', according to the effect of heat on their properties. Thermoplastics, like metals, soften with heating and eventually melt, hardening again with cooling. This process of crossing the softening or melting point on the temperature scale can be repeated as often as desired without any appreciable effect on the material properties in either state. Typical thermoplastics include nylon, polypropylene and ABS, and these can be reinforced, although usually only with short, chopped fibers such as glass. Thermosetting materials, or 'thermosets', are formed from a chemical reaction in situ, where the resin and hardener or resin and catalyst are mixed and then undergo a non-reversible chemical reaction to form a hard, infusible product. Thermosetting resins such as polyester and epoxy cure by mechanisms that do not produce any volatile by products. Once cured, thermosets will not become liquid again if heated, although above a certain temperature their mechanical properties will change significantly. Although there are many different types of resin in use in the composite industry, the majority of structural parts are made with three main types, namely polyester, vinyl ester and epoxy. Polyester resins are the most widely used resin systems, particularly in the marine industry. By far the majority of boats built in composites make use of this resin system. Polyester resins such as these are of the 'unsaturated' type. Unsaturated polyester resin is a thermoset, capable of being cured from a liquid or solid state when subject to the right conditions. It is usual to refer to unsaturated polyester resins as 'polyester resins', or simply as 'polyesters'. There is a whole range of polyesters made from different acids, glycols and monomers, all having varying properties. There are two principle types of polyester resin used as standard laminating systems in the composites industry. Orthophthalic polyester resin is the standard economic resin used by many people. Isophthalic polyester resin is now becoming the preferred material in industries such as marine where its superior water resistance is desirable. Here is a link to one manufacturer’s preferred Isophthalic (type 404 – tooling polyester resin) and their standard Orthophthalic (type 435 – marine grade resin) that are suitable for most repairs: http://www.uscomposites.com/polyesters.html Either of these would be used as manufactured for all but the final layer of the repair. If no chemical or physical means are used to eliminate air from the surface of the repair during the curing process, the lamination will cure to a tacky state. This is often desirable while laminating multiple layers and hence, I believe, lead to the common use of the term “laminating resin”. “Finishing resin” on the other hand, is commonly used to designate a polyester resin that will fully harden making it hard enough to facilitate sanding. The addition of a surfacing wax to unwaxed polyester resin effectively changes it from a “laminating wax” to a “finishing wax”. Surfacing wax is not mold release wax as described elsewhere in the thread. This particular manufacturer sells only unwaxed polyester resins; therefore they sell surfacing wax to add to their resins as well as mold release wax (which is used to facilitate easy release from a mold). I suspect that other manufacturers may not sell a specific surfacing wax because they sell both “laminating” and pre-mixed “finishing” resins along with mold release wax. This may explain why confusion exists about incorrectly using mold release wax as a surfacing wax. Here is a link to the same manufacturer’s surfacing wax: http://www.uscomposites.com/solvents.html Note that this manufacturer also sells distinct mold releases in spray on and wax forms: http://www.uscomposites.com/moldrelease.html I hope this helps to clarify the basics of polyester resins and their use. I did not include any information about gelcoats as this was not included in jimh’s initial post. That is a whole thread worthy subject in itself. |
| Jessielove |
Woops, I intended to write near the end of my last post "The addition of a surfacing wax to unwaxed polyester resin effectively changes it from a “laminating [RESIN]” to a “finishing [RESIN]”... |
Good information on the resins types and the waxes. Thank you. Sorry that my memory does not permit me to say the precise brand of polyester resin I used. It was purchased at WEST Marine. I don't think that my prior experience is in any way binding on the science and art of polyester resin repairs, that is, what I did makes no difference to the advice that experts will offer me. |
| Binkster |
Jessie Good informational links. as I'm in the process of building a plug and a mold to make fiberglass center consoles. The info on tooling gelcoat and resin is helpful to me. |
| Owtrayj25 |
[Changed TOPIC to again talk about my memory. Please stop distracting the discussion. We are interested in advice about polyester resin techniques, not your comments about my memory. --jimh] |
| RM NY |
"adding wax" for purpose of gelcoat or resin cure you would use a TFA wax, NOT mold release wax. Mold release wax is just that and usually found in a can like automotive wax and spread with a applicator. TFA is liquid, but it will gel when it sits you want to give it a little shake before using it, and its poured into your resin.
People blame polyester resin for mistakes they made in their repair procedures, professionals all over the world have success with polyester resin. When they stop building boats with it that is when I will stop using it. |
| dfmcintyre |
Rob - Great information. Question - Have you had any issues with shrinkage of a repair over a ten year time frame? Specifically, say a bolt hole pattern from a deck mounted downrigger or cleat showing up years after the initial filling and painting? Regards- Don |
| RM NY |
First off- 10 years ago resin and gelcoat was better then it is now. I could go on for days why, again just realize that when you see so many different brands of boats come and go through the gates you get a good idea of whats going on. You think gelcoats are tricky to work with? Try working with these lousy LE ( low emissions ) gelcoats. I will go one further- if I told you that I have tried practically side by side comparisons of different resins and notice no difference would you believe me? Different fairing compounds, etc. I have gone so far as to email people around the country who are also involved in these boats and asked them if they notice the shrinkage and the answers are all the same. Even one stored indoors in a year round climate controlled garage. |
Many thanks for the clarification regarding the wax added to resin to get a hard cure. It made no sense to me that one would use mold release wax (as was recommended above), so I am glad you clarified that recommending mold release wax as an additive wax was bad advice. It seemed like bad advice to me, and I have no experience with using polyester resin for repairs with wax additives. |
| ConB |
Earlier in this thread I asked if Boston Whalers were still being built using polyester resin. I didn't know because there is other stuff being used by some boat builders, so I emailed Chuck Bennett at Boston Whaler and he replied that Whalers are built using polyester resin. Con |
| MarkoOR18 |
Re Spectrum gelcoat mentioned above, and in particular, the color match. I'm a noob about to start repairing my console. If I order the Spectrum in Desert tan, what tints should I order so I can fine tune the color. just black and white, or will I need more than that? thanks Mark |
| Binkster |
Actually it takes a good eye and alot of practice and a knowledge of colors to match paint. Black and white will only give you shades of grey. I think Desert tan has a bit of burnt umber or raw sienna in it to warm it up. When I was young I worked in a paint store (before there were computers to match colors) and we did it all by eye. It took a bit of practice and some ruined paint till you got good at it. |
| MarkoOR18 |
Thanks for the tips. I did more research this aft, and see that sienna is a common tint to have on hand. |
