posted 05-30-2012 12:47 PM ET (US)
I was planning on replying to your other thread after using my boat with twin engines and Lowrance EP-60 fuel flow sensors installed, but forgot to check the flow rates or grab my log book this past weekend.Hopefully tomorrow night I will run the boat and compare notes with you. In the mean time, this is what I have noticed about the Lowrance sensors.
First thing to check is that the sensors are configured for port and starboard and that you are not inadvertently reading combined fuel flow from both. I mention this, because my sensors came factory configured both as starboard. If you have already done this, then disregard the following: Be very careful when changing configuration settings for those sensors. DO NOT delete the sensor from whatever head unit you are using to read the data. Once you delete the sensor, it will never again show up when you scan for devices, and the only fix is to send it back to Lowrance for a replacement.
Second, I question the instantaneous accuracy of these sensors with carburetor engines. My fuel flow readings jump all over the place. Perhaps this a result of the pulsing in the fuel lines due to the crankcase pressurized fuel pump, or the VST filling up and draining to the carburetors. I don't know the reason, just that I have noted fuel flow and fuel economy readings are too sporadic to get good real time info without doing some mental averaging. I have not found a way to set up the sensors to sample less frequently or average the flow for a few seconds. If you figure this out, please share.
I would suggest that you try averaging the data yourself and see what you get for idle fuel consumption. Try resetting your fuel used to zero, then after a measured amount of time take down your fuel used value and multiply it out to see what you would burn in an hour. For example, reset the fuel used, idle your engine for two minutes, then multiply your fuel used times 30 to see what your hourly rate would be. This would at least confirm the accuracy of the instantaneous values you are getting.
I will have more to add in a couple of days.
