  Optimax On Engine Oil Reservoir Tank .... low oil level
Author Topic:   Optimax On Engine Oil Reservoir Tank .... low oil level
bluewaterpirate posted 06-12-2012 07:59 PM ET (US)   Profile for bluewaterpirate   Send Email to bluewaterpirate
I know this has been discussed before but I wanted to do a short video explaining the problem and a temporary solution to the problem. It happened to me over the weekend.
Mercury Smartcraft Guardian System.
Alarm
Four beeps every two minutes indicates the possiblity of two different causes.
1. Water in the fuel filter
or
2. Low level oil in on the on engine oil reservoir tank
Guardian System will:
Restrict engine RPM's which equates to speed restrictions
Temporary solution to the problem. But like with every temp solution it could cause a catastrophic engine failure.
Video; if you have high speed Internet click on the HD icon after the video starts.
http://bluewaterpirate.phanfare.com/5621532 [Link No Longer Works--jimh]
om
mtwilling posted 06-12-2012 11:07 PM ET (US)     Profile for mtwilling  Send Email to mtwilling
I had this very problem while on vacation with my boat last week. I had determined that I had a faulty sensor on my 135 Opti and had a mechanic make a wire lead just as you described. It saved my trip until I can replace the unit.
ukuslayer posted 06-15-2012 12:02 AM ET (US)     Profile for ukuslayer  Send Email to ukuslayer
Great video Bluewaterpirate,
I have 1999 225 Opti. I have never had that problem but seeing your video has made me think it would be a good idea to rig up a jumper and order a replacement sending unit. Mine is still the original unit. I like the ease of the fix if it happens on the water with the jumper.
I have the four section alarm gauge on my dash from earlier models but I keep a copy of all the alarms and the corresponding lights for my gauge on the boat with me at all times. I also have a spare belt on the boat and plugs, filters and various other parts on board, I will now be adding the jumper and a new sensor to what I carry on board. Such a simple fix for a major problem if it happens, to get you in to shore. Thanks for posting such a clear and easy to follow video.
Aloha,
Sean
bluewaterpirate posted 06-21-2012 01:16 PM ET (US)     Profile for bluewaterpirate  Send Email to bluewaterpirate
The sensor inside my on engine oil reservoir was the sensor that went bad. I tired cleaning it and it worked for an hour but the fix failed so my next/only choice was to buy a new tank to replace the old one. The cost was $68.00. This is the original tank/inside the tank sensor that came with the boat 10 years ago and 4283 hours of use later.
Pictures are worth a 1000 words.
http://i676.photobucket.com/albums/vv129/bluewaterpirate/ Optimax%20225%20%202002/OilTank.jpg?t=1340297574
The external sensor that goes into the sleeve on top of the tank. This plasitc sword sensor is inserted into the hole for the sleeve that resides on top of the tank. It does not come into to contact with the oil inside the tank but sends an electrical current to the magnetic sensor inside the tank the monitors oil level and warns you if the tank oil level is low through the Mercury Guardian system.
http://i676.photobucket.com/albums/vv129/bluewaterpirate/ Optimax%20225%20%202002/IMG_3767.jpg?t=1340297109
http://i676.photobucket.com/albums/vv129/bluewaterpirate/ Optimax%20225%20%202002/IMG_3759.jpg?t=1340297092
http://i676.photobucket.com/albums/vv129/bluewaterpirate/ Optimax%20225%20%202002/IMG_3760.jpg?t=1340297100
http://i676.photobucket.com/albums/vv129/bluewaterpirate/ Optimax%20225%20%202002/IMG_3768.jpg?t=1340297118
http://i676.photobucket.com/albums/vv129/bluewaterpirate/ Optimax%20225%20%202002/OptiFilter1-2.jpg?t=1317661461
