Topic: Montauk Front Deck Mounting
JoeDon |
posted 11-03-2012 08:00 PM ET (US)
I recently bought a 1974 Montauk that has a front platform, which is not installed, but which I want to install. It seems there are several mounting boards missing and I am trying to find information on how these platforms attach to the inner hull and the proper type and location of board. Any help would be appreciated.
Freddy
posted 11-03-2012 10:51 PM ET (US)
JoeLook up about 5 inches to the right, there will be a box with the words new topic in it. Just under that is the search section. Click that and key in front platform. Also you can enter casting platform. Good luck. |
Sourpuss1
posted 11-05-2012 08:30 PM ET (US)
On my 74 Montauk II there were: 2 long "cleats" (aprox 1-1/2" square? X 4' long) that sat on the small inner shelf of the hull, attached with screws horizontily, two short pieces of the same size screwed to each side of the console, 2 short pieces screwed to the front of the console close to the outside corners, and one piece accross the front directly behind the front locker. Unfortunatly, I owned this boat before the advent of digital cameras, so I don't have photos. I know where the boat is, and will see if I can take some measurements (and photos) for ya. Pete |
JoeDon
posted 11-06-2012 08:40 PM ET (US)
Pete,That's exactly what I was looking for, I did search the site but haven't come up with a better description than what you have provided so far, thank you. I am assuming these boards were teak....? JoeDon |
JoeDon
Sourpuss1
posted 11-07-2012 12:06 PM ET (US)
Took some photos... 1974 Montauk II [img]https://picasaweb.google.com/116270698488929759014/BowPlatform?authuser=0&authkey=Gv1sRgCNn_t-qiipCveQ&feat=directlink[/img] The side "cleats" are 1-1/8" tall and 1-1/4" wide They are not teak (they are currently painted white). The console pieces are teak, and are thru-bolted to the console. Hope this helps, Pete |
JoeDon
posted 11-07-2012 08:57 PM ET (US)
Pete,These pix are very helpful, thank you! |
Sourpuss1
posted 11-12-2012 03:07 PM ET (US)
JoeDon, Please post some pictures of your installation! It's going to be long winter.... Pete |
