Topic: Life with Merc/Yamaha 90hp carbureted FourStroke
pcrussell50 |
posted 02-16-2013 04:09 PM ET (US)
My particular story:February 2011: bought an awesome 1998 17 Alert/special service Montauk from CWW member Fishnff/Brian, with a 2000 Mercury 90hp carbureted FourStroke, knowing only that these carbureted motors like/need to be run often. It already had/has a large external 10 micron water-separating fuel filter. Feb 2011-Fall 2011: started it and ran it on the muffs in the driveway more or less weekly, certainly no less often than every other week, but mostly weekly. But did NOT take it out in the ocean very often where I could put some load/speed on it, (and I think that is important). By late fall, it was not always liking full power. It would either stumble on and off at full power or simply get "stuck" and not even go into the full power circuit. Usually in the cold rough Pacific, mid-power is all you want. Fall 2011: I spazzed (term of high literacy) and assumed clogged carbs right off the bat, and with more mechanical skill than sense, tore the carbs off and disassembled them, cleaned them, and put them back together, without first doing any other diagnosis. Discovered one of the carbs had a badly gunked-up, sticky needle. I sort of cleaned it (the deposits were very hard to remove), so I just unstuck it, and called it good... definitely not good surgical technique. I should have replaced it. It started at the first crank, to a stumbly but reliable idle. I did not have a balancing tool, and did not realize the importance of one. Fortunately, I did not disturb the settings too badly so it ran OK (but not like you would want a brand new engine to run). I continued to run it on the muffs every week or so, but did not take it out in the ocean due to being tied up with other priorities. Spring 2012: Took her out in the ocean and she would not get out of idle without dying. I started to get more serious about the importance of proper balancing (of the four carbs), and on the GREAT advice of CWW member sosmerc, got a very good balancing tool for less than a 10th of the cost of the digital vacuum mate. It is the Motion Pro products, Sync Pro. And it is ~$100. Talk to me before you buy one though. I did a quick and dirty balancing job, (turned out I did a poor job, but it was my first time). Was still getting random stalling and not able to get to full power. So I got discouraged and "shelved" my interest in this boat and concentrated on other things for a few months. Fall 2012: Stripped off and cleaned the carbs again, this time paying more attention to blowing carb cleaner through all the little passages. Started it up just fine and ran it on the muffs once a week. Took it out on the ocean and wouldn't go to full power. Got discouraged again and shelved it again for the holidays. January 2013: Decided to get more serious about balancing it right. Only this time it was VERY hard to start. Weird because prior to that in the fall, it started right up to a stumbly but reliable idle. So I screwed the idle speed screw all the way in (to full fast), and eventually got it started. So now I have a problem with cold starting, but it runs ok once warm. Great, another problem. Removed, cleaned and tested on battery the cold start enrichers, they were fine. Still hard to cold-start. Another trick I used once it was _barely_ running was to loosen the set-screws on the TPS and advance it by twisting it. That worked very will (BIG clue, btw), in getting it warm and stable idling. This time, I hooked up my balancer tool (the Motion Pro SyncPro), and did a thorough job balancing it. It was purring along pretty nicely. I was confident. Took it out in the harbor with kid, wife and buddy, and putted along hither and yon inside the harbor in quiet four-stroke bliss. Then we left the harbor and when I put the coals to her? Stutter-stumble-die, stutter-stumble-die. After a few times of that, even the idle began to become unstable and unreliable. @#$%^&*!!! By now though, I LIKE the novelty of the quiet idle and great fuel economy of this big heavy four-stroke. Hey, it's a Whaler, not a speed boat. I already have fast boats with light powerful (reliable) carbureted two-strokes for going fast. That's not what a Whaler is for though, and I have no interest in making it that way. Stripped all the carbs off one more time, (by now, it's easy), for a thorough cleaning and this time, I ordered new needles and seats from Yamaha. These 90hp Mercury powerheads are in fact IDENTICAL to the Yamaha F100 powerheads of the same year, and shockingly, the Yamaha parts were a little cheaper. Both Keihin BCF carburetors with identical jetting. Put it all back together again and? BAM! Hard to start. Basically will not cold-start unless I screw in the idle speed screw and fiddle with the TPS once it "catches" into a barely running idle. When it warms up, it idles pretty nicely and I back out the idle speed screw and set the TPS to full clockwise (it has slotted mounting screws), the way the manual says to, (hint hint). By now, I've cold-start-nursed it into a steady warm idle a half-dozen times. I have almost no fear at all of a no-start. Fear of "no-start" was a recurring theme in quite a few of the other threads on here, so this is BIG news to me and even with problems, makes things HUGELY better for my confidence in this thing. Mid-February 2013 (yesterday): The day before yesterday, I had yet another hour or so of good running on the muffs after what has become a standardized ritual getting it cold-started. So yesterday, I take the boat down to the harbor by myself (no wife and kid while it's still risky). While tied to the dock, I try the standard, turn the key as if it's a new motor, and it will not start, just cranks and kicks. No biggie. It has been this way for a month now. I pull off the cover and do my usual tricks to get it started and warm and it works just like it has for the last month. Now I've got a warm idle. It is important to know that BOTH advancing the TPS and screwing in the idle speed screw will increase the idle speed. The manual says the TPS should be all the way clockwise in it's slots, but now I am suspicious of it, so I set it to a point where it very slightly speeds up the idle, then I compensate by turning the idle speed screw back out far enough to get a proper idle, and head out into the harbor. Putting along through the "no wake" zone goes well. When it's time, I put the coals to her and? Stumble sputter go, stumble sputter go. On plane, but not quite wanting to get into or stay in, full power. But someone else in another thread talked about how he soldiered on this way until his finally "cleared up", so I decided to keep her floored and see if she would clear up. But my carbs should have been clean. I just did them a couple of weeks ago. After a few minutes of "stumble stutter go", "stumble stutter go", waiting for things to "clear up", I realized I didn't have my lifejacket and headed back to the dock to go get it out of my car, (I brought it, but I left it in the car). THIS time, on my growing hunch that the TPS is bad, I moved it a little more counter-clockwise, which advanced the idle speed a little faster, and turned the speed back down again using the butterfly screw. Remember, the manual says the TPS should be all the way clockwise. So, I putted back out nicely through the no-wake zone as before. When it was time, I put the coals to her. And? This time she explodes up to full power!!! No more "stumble stutter go". Just "go". I ran her hard at 4000-5500 rpm for 20 minutes straight without a single stumble. Woohoo. Satisfied, I putted back through the no-wake zone to the dock at low power. At the dock, at full closed idle, she didn't quite want to keep idling, so I pulled the cover and turned in the idle speed screw just a wee bit, and? Purrrfect :) This motor is very sensitive to slight adjustments. And they all affect each other. Lot's of thoughtful fiddling is rewarded with this motor. So now what? Something is still wrong. At the very least, I am not getting the timing advance I am supposed to be getting on cold-start. I do not know if it's the fault of the TPS, or a temp sensor, or the CDI itself (though I hear these particular CDI's are pretty reliable). As for the TPS, I do not know if this a rudimentary, two-position, binary, hi-lo TPS, or if it reports a continuously varying voltage from the beginning to the end of it's sweep. I also don't know if the CDI sets timing on a smooth curve, or has a programmed "step", where it goes from advanced to retarded to advanced again or what. If this were an EFI system, I would know. So either the TPS is bad or something else that affects timing is bad. I don't know which yet. In the mean time, I have found an uneasy peace with this motor. I feel like I know it's tricks, and know what to do when, with it, so I don't end up stranded. And I'm VERY happy with that. (Hear that, Brian? If you read this, do not feel bad for me. I am very happy with my purchase.) I am learning things about this motor hand-over-fist, and it is fun learning. I have high hopes of getting it running like new eventually, but in the mean time I can still use it just fine as it is. More to come... -Peter
FISHNFF
posted 02-18-2013 02:36 AM ET (US)
Happy New Year Peter! I am sorry about yours troubles. It's been pretty good when I had it, so can't really comment on how to debug. When I first got it, right off the bat, I had an acceleration problem that was solved by float synching the carbs. Funny, as it was fasted then. I hit over 39knots (solo with tide) with a 19" prop, but had to nurse onto plane. A 17" prop gave me 35 +knots. The 15" trolled best. I ran Mercury Quikleen regularly. I believe in that stuff, and make sure you have good gas. Best, FISHNFF |
pcrussell50
posted 02-18-2013 01:51 PM ET (US)
Don't give it a second thought Brian. I'm thrilled with it. Thrilled with having this thing that I can know inside out and backwards. That means I'm actually_glad_ this FourStroke is carbureted. BTW I don't think the cold start difficulty has anything to do with clogged carbs. That means its a failed part that could as well have failed on any motor with 875 hours?BTW did you ever have the valve clearances checked and adjusted? -Peter |
wezie
posted 02-19-2013 10:11 AM ET (US)
Thanks for the detail Peter. Your posts are always interesting. Once into the electrical part, I get lost. Primarily because some nit wit added another component last week. My Merc has been great lately. Just needs to be run.Thanks again. John |
swist
posted 02-19-2013 04:57 PM ET (US)
We owners of said engine should start our own forum! |
AZdave
posted 02-19-2013 10:50 PM ET (US)
My 90 Mercury Four Stroke is a 2005, and has fuel injection. It's instant starting has made a huge difference for us, as my wife happily launches and loads the boat. It has started missing at low rpm, and I took it in for diagnosis. It has 200psi compression on three cylinders and 115 on one. A big squirt of oil brought the compression back up to 185psi. The plugs look perfect and the computer reports no codes in 230 hr of operation. I should get to see it with the head off this week. No happy campers here. |
swist
posted 02-20-2013 05:16 PM ET (US)
It was my impression that the EFI version of this engine is in fact perfectly normal and reliable. |
contender
posted 02-20-2013 06:50 PM ET (US)
After reading your post on your Mercury, sounds like you have no life with your Mercury |
posted 02-20-2013 07:36 PM ET (US)
Peter,Have you used Marine Sta-Bil at any point during this process? Butch |
pcrussell50
posted 02-21-2013 12:11 AM ET (US)
Butch... Only regular Sta-Bil so far. And this particular tank I started trying StarTron on Sosmerc's recomendation. I did buy a small bottle of marine StaBil to try next.Hang on for more updates soon... With these motors, notwithstanding the lore, not every problem is due to clogged tiny passages. -Peter |
posted 02-21-2013 10:05 AM ET (US)
Peter,Carburetors can be very frustrating. In the sixties while stationed in Germany I did a lot of Porsche 356 tuning which for the most part included carburetor balancing. The SCs were the most challenging. After some poor results I finally got the hang of it and had a lot of fun while making a few marks in the BOQ parking lot. Eventually I became so busy I had to price myself out of the market in order to have some time to enjoy Germany. It seemed that every young single officer in the area had a 356. A background in racing Ford flatheads with triple carburetors was an immense help. Butch |
swist
posted 02-21-2013 03:36 PM ET (US)
Everyone has their own idea of what witch's brew works best. The ethanol version of Stabil seems a common recommendation, though. And my guy says Quickleen too. I've never really had a problem (bit of rough idle & balky acceleration one season, but that was fixed by chopping off the mixture screw seals and adjusting a bit richer). Peter, I wish I could share your enthusiasm for solving these problems. I'm out in the cold unforgiving ocean a lot, sometimes with small kids, and I have to say, the slightest burp (always something other than the engine, most probably my imagination) makes me nervous. I really wish I had an engine that gave me more confidence. If the engine in my 2008 Subaru failed, I think I'd actually be shocked. Wish it were the same with good old carbed 90.
pcrussell50
posted 02-21-2013 07:05 PM ET (US)
The main source of my enthusiasm is that I no longer fear getting stranded. My carbs are recently clean (by me), and with a Phillips head for the TPS and idle speed screw, I feel ready for whatever tricks this sucker has thrown at me (so far anyway), and being carbureted with a limited sensor suite, there isn't much. As my pro mechanic said to me yesterday, "EFI motors have problems too... Only those, you don't fix at sea or even in your driveway". He's the local official Yamaha service rep. He knows my Merc pretty well because it's really a Yamaha... And has had plenty of work from customers unable or disinclined to go elbows deep in the Yamaha versions of these things.Don't get me wrong. I like EFI as well as the next guy. My race car is EFI, and I have invested in all the expensive testing and tuning gear for it, and build the motors myself. But I'm just as glad to have this outboard motor be carbureted, and for the reasons already stated. -Peter |
huckelberry145
posted 02-21-2013 10:47 PM ET (US)
Poor ole carbs, they are like "stepchildren" and get blamed for everything. The flywheel hasn't slipped the key a little has it. |
pcrussell50
posted 03-01-2013 06:37 PM ET (US)
In keeping with what I titled this thread, it will be an ongoing "blog" if you will.Sooo, the latest. I did not want to chase down things like bad CDI's or rectifiers myself, and the motor was due for it's 800 hour service anyway, so I took this Mercury to the local (if you consider a 30 mile freeway drive local) Yamaha dealer's head mechanic... Tony Johnson, a young but savvy mechanic with a great, pro-customer demeanor. I tried to demonstrate the hard cold-starting for him, but it started right up anywyay. I had run it on the muffs earlier that morning and thought it had cooled off enough to demostrate a hard cold-start. Tony, wise beyond his young years, said he likes to to a leakdown check on just about every motor that's having problems, and I agreed. I should have done a leakdown check myself, but I lent my leakdown tester to a buddy (months ago) and haven't asked for it back, (I've had his engine hoist for more than a year, so I'm not feeling slighted). Before he did the leakdown test, he fired it up again and closed off the pilot jets one at a time, and when he did the bottom one, it did not stall the motor and had very little effect. So no surprise that Tony found the top three cylinders nice and tight, and the bottom cylinder was leaking about 22 percent through the crank case. That would have made me think it was a worn bottom cylinder and I'd be sunk with despair. But that's the difference with a pro mechanic and a guy like me, even though I have the knowledge and skills to build motors from a pile of parts, that still does not develop diagnostic skills like a pro mechanic. Next, he did a compression check and all four were crackling high, even the bottom one. He knew immediately that it was probably stuck rings from carbon. He stuck a probe in the bottom cylinder and scraped off some carbon and that made him even more sure. He de-carboned the motor, (I did not ask him his technique), and sure enough, the leakdown numbers are up where they should be even for the bottom cylinder. He said it runs MUCH better now, and I didn't have any serious problems with it before other than the hard cold starting. So maybe the leaky number 4 cylinder (bottom) was it all along? The 800 hour service also calls for checking and adjusting the valves, so there is even more room for improvement. We'll see. I'm going to ask him to check resistance in the cables from the battery under the console to the motor. With one battery like I'm running it now, it cranks a little slowly at first and I wonder if that causes a weak spark that makes cold starting harder? I was going to go back to dual batteries, but I didn't want to pay good money for a couple of new ones until I had the motor running satisfactorily... which it looks like we're heading for. One other thing, he noted that I had the carbs balance up quite nicely with my $99 motorcycle, 4-carb manometer. So I won't be investing in the $1500 vacuumate. -Peter |
posted 03-03-2013 09:06 AM ET (US)
I don't think I ever owned a car with more than one carburetor. Could you explain exactly what is adjusted when you are setting the balance on the carburetors? |
tedious
posted 03-03-2013 10:09 AM ET (US)
Jim, you're adjusting the throttle butterflies relative to each other so the airflow through the carbs is equal. The carb sync tools are all some type of manometer (air flow meter). Easy enough to do - learned on a Triumph TR7 and Datsun 240Z, to date myself.Tim |
pcrussell50
posted 03-03-2013 10:44 AM ET (US)
Precisely, you are adjusting the throttle butterfly angle of of each carburetor with respect to the others. Why? So that each cylinder pulls the same vacuum at idle with respect to the others. So that each cylinder can have the same signal draw on the fuel as the next, as to make for smoother acceleration. Our OMC's (your old v6 and my gaggle of v4's), lack the ability to adjust throttle angles with respect to the others. Those are fixed by design. There were many high performance cars from the carburetion era, mostly European some American, that had multiple carb setups. A short straight shot from the intake to the cylinders, identical for all cylinders is good. A growing number of modern efi motors are the same way. My wife's modern BMW v8 has eight individual throttles, one for each cylinder, but they are covered by a common plenum. -Peter |
wezie
posted 03-04-2013 07:26 PM ET (US)
Finding that thorough mechanic is such a great moment. It allows you to sleep at nights. Shame there are not more. |
pcrussell50
posted 03-30-2013 12:19 PM ET (US)
Good news and interesting news...In my last installment, I had the motor in the shop for it's 800 service. They found the leakdown on the bottom cylinder to be too fast, and did a de-carbon treatment, which brought the leakdown up (down) to match the others. Just got the motor back after several weeks, having told them to take their time, because I was going overseas and then I was sealing cracks in my driveway and just as happy NOT to have my Whaler around and in the way. They finally called me last weekend and asked me to come get it, (they were probably on to me, using them as free storage ;) ) The good news? The bill. $575 out the door including tax, parts, and labor. And that was for a MAJOR service which includes valve adjustment, in a VERY expensive part of the country, in a shop that is in a marina. I was satisfied with that price, pleasantly so. The interesting news? The carbon. Runs like a top after a thorough de-carboning. That was the only thing the shop could put a string to as to why it runs so well now, and not as well when I brought it in. (Remember, when I brought it in, it was running fine for my uses. A little hard to cold-start and fiddly on some adjustments, but otherwise, nothing that would ruin my day). Interesting news 1a: The previous owner was religious about using quickleen for his 800+ hours of ownership. I put about 50 hours on it in my two years, leading up to now. For the last two tanks before servicing I didn't use Quickleen. I used Techron. And those two tanks are when I started having non-new-quality running issues. Could it be the Tehcron? Doubt it. I'm _sure_ it would take more than two tanks to carbon up an engine. Further, my running problems started almost as soon as I added the Techron. Carbon definitely doesn't build up instantly. And further still, Techron is a well known and well respected and established product. Interesting news 1b: So, they de-carboned it, and they said they found a LOT of carbon over all, in all four cylinders, (remember, it was the only bottom cylinder that had the stuck rings though). So what's interesting? After 800+ hours of religious use of Quickleen, it still carboned up. Thoughts: Maybe that means that even good additives will only slow the buildup, not stop it, and that de-carboning is still necessary periodically for some motors? Recall, that the 50 hours I put on this motor were over the last two years and that 35 of those 50 were probably on the muffs in the driveway, idling. My conclusion: As with the old Evinrude saw of blaming everything on VRO, don't be too quick to blame everything with this motor on the carbs. I took mine off and cleaned them three times, chasing this problem which turned out to be carbon. BUT, if you're sure it's the carbs, they are not that hard to do, (slow going, but easy work), and you don't need the $1500 Vacuumate balancing tool. The $110 liquid motorcycle manometer from Motion Pro worked just fine for me. Even the professional techs told me I had it balanced just right. Anyhow, for now, as of my first time out since the de-carbon work and 800 hour service, the motor is running about like new. Easy cold-starting, transparent, turn-the-key-and-go operation, indistinguishable from an EFI four stroke... except we can work on it ourselves. -Peter |
posted 03-31-2013 09:20 AM ET (US)
Thank you for the very interesting narrative.My anecdotal observations about fuel and carbon: some gasoline seems to produce more soot in the exhaust than other gasoline. I have an engine whose cowling is painted white. The exhaust idle bypass will typically develop some soot on the cowling after running a tank of gasoline through the engine. My usual boating pattern is to run the boat for a week at a time. At the end of a week, I haul the boat and wash down the engine cowling. I note how much soot has appeared on the cowling in the area around the exhaust idle bypass. Although I tend to run the boat with the same sort of engine speeds and loads all the time, the amount of soot varies. I recall one tank of gasoline I got that produced a lot of soot. I don't know if that meant the gasoline was especially good--because it had a lot of cleaning additives that loosened old soot and carbon in the engine and expelled it in the exhaust--or if that tank was especially bad--because it created all that soot I saw. |
Marsh
posted 03-31-2013 09:45 AM ET (US)
How does one de-carbon an engine? Is it as simple as running the engine using some sort of special fuel additive? Or is there a mechanical aspect to it? Scrubbing or scraping, for example? |
skram
posted 04-03-2013 12:29 PM ET (US)
It would be interesting to discuss the de-carbonization of these Mercs. There seems to be two main issues with these engines, the carbs (which other than rebuilds don't have a long term solution to the problems) and carbonization issues. I haven't seen a real discussion on how to de-carbon so would appreciate any suggestions or how-tos. Thanks |
gnr
posted 04-03-2013 03:29 PM ET (US)
quote: started it and ran it on the muffs in the driveway more or less weekly, certainly no less often than every other week, but mostly weekly. But did NOT take it out in the ocean very often where I could put some load/speed on it, (and I think that is important).
Letting two strokes idle in the driveway repeatedly without ever running them hard will cause carbon build up problems.
If your not going to run it up to temp under load you're better off to leave it be. |
95Outrage17
posted 04-03-2013 08:05 PM ET (US)
Although, it wouldn't be a bad idea, and I may do so this spring, I have never de-carboned my 2004 Mercury 90hp Fourstroke. I bet it has somewhere in the vicinity of 1000+/- hrs, but I do not have an hour meter. I usually use 89 Octane fuel, always Mobil 1 synthetic engine oil and fuel stabilizer when stored for the winter. The motor has had some carburetor work, but not in the last several years. It starts easily and runs great. On most runs it sees at least a few seconds of WOT, but is often cruising on a plane at 3000 - 3500 RPM. Overall I've been pretty happy with this motor.- Chris |
pcrussell50
posted 04-04-2013 05:13 PM ET (US)
quote:
Letting two strokes idle in the driveway repeatedly without ever running them hard will cause carbon build up problems.If your not going to run it up to temp under load you're better off to leave it be.
This motor is a four-stroke-cycle motor. A Mercury 90hp FourStroke. But your point is well taken. -Peter |
EJO
posted 04-09-2013 10:14 AM ET (US)
So any info on how to de-carbonize these engines? 2008 60HP Merc. Bigfoot |
95Outrage17
posted 04-10-2013 10:00 PM ET (US)
Buy some Mercury Power Tune and follow the instructions on the can. Should be fairly straight forward. - Chris
pcrussell50
posted 04-26-2013 01:09 AM ET (US)
The good, (no, perfect) running continues after my last installment. I hauled her out to the lake house a few blocks from Lake Mead, to give her some much deserved fresh water, and hard running. See, the Pacific Ocean in the Santa Barbara Channel is rarely smooth enough for long running at high power. This fact alone might have been a big contributor to the carbon buildup issues I had. A week ago tomorrow I put a 40 mile round trip on her in smooth water, including some long running at 5500 rpm. She didn't miss a beat. It was an interesting niche boat on Lake Mead last Friday. By far the most common boats are evenly mixed between huge monstrosity deep vee v8 offshore-type boats and wakeboard boats. Fishers are probably 15% on Lake Mead, and half of those are bass boats, the rest being aluminums. I have yet to see another classic Whaler besides my own, actually running. Some of the fishermen were giving me nods and waves (even though I wasn't fishing, my boat is covered in rod holders), and on the slow motor in through the no wake zone, at least one complimented my boat and asked me how the fishing was, (fooled by the rod holders again).Anyhow, I'm very high on this boat/motor combo right now. Especially since I've taken the heads and transfer covers off my Hydrostream's "Frankenstein" v4 crossflow in an attempt to determine it's origin. So my 17 Alert/special service Montauk is my only runner at the lake until I button the v4 back up. Which reminds me... WHOA! Does this 90hp FourStroke ever sip fuel in comparison to my fast, lightweight, but old carbureted two-strokes. -Peter |
FISHNFF
posted 04-30-2013 12:22 AM ET (US)
Hey Peter, Glad she's running like a dream again! I really loved how she purred. I swear she was every bit as smooth as my Yamaha 115 EFI. |
FISHNFF
swist
posted 04-30-2013 10:17 AM ET (US)
Hi Peter,Now I'm over 500 hours and haven't ever decarbonized the motor. Nor have had even the slightest carb problem since knocking off the EPA plugs and adjusting the mixtures "properly". The last 3 years, I've settled on Blue Stabil + Quickleen as my witch's brew, and that seems to be the winning combination. I tend to cruise at 3800-4200 pretty con stantly, and wonder sometimes if more variation in engine speed will help longer term to keep things right at other throttle settings. I'll hit WOT for a minute or so every other time out. I know it's the right thing to do for clearing out deposits, but I still have psychological issues with this engine - fear that running it at WOT for more than a minute will shake something loose since the engine is supposedly so "delicate". Not completely rational, and no evidence whatsoever, but always comes to mind. Moot point anyway as I am on the ocean in Maine and there are few opportunities for running at WOT, particulalry since I am lazy and usually don't go out until the afternoon when it is warmer, but also windier and choppier. Jim |
kwik_wurk
posted 04-30-2013 12:16 PM ET (US)
Well, I spent the last weekend de-carbing 3 motors and rebuilding 6 carbs. Went through several cans of decarb spray, carb cleaner fluid, and rubber gloves.I think it was 6-7 hrs total. (Plus one impeller) -- But I was working on the water (boat house), and it beat a day in the office. One trick I do for balancing and set points of all the carb needles and valves, is before I unscrew items, I screw them in all the way until the stop while counting the turns. (Write it down somewhere, when I put it back together it goes in the same spot/point.) -- Or I etch an alignment mark. One comment about carb build up, use marine grade oils and products in engines. Marine grade oils have much more detergents in them than automotive types due to regulations. This will also help prevent carb build up. And I have found that different carb bowl materials respond drastically differently to ethanol. Most of my engines use the same gas, but the level of crud in some bowls is 10:1 regardless run time. |
BQUICK
posted 04-30-2013 02:26 PM ET (US)
Another issue is that with 4 strokes running at idle in driveway never gets the oil up to temp to burn off condensation that forms as it tries to warm up. Does more harm than good. Reminds me of a motor I went to check out and when the guy said he ran it EVERY week for 10 minutes in his driveway to keep it in "good shape"....I ran away. |
Jamesgt727
posted 05-05-2013 12:48 PM ET (US)
P, great story and data. On all of my small boats, with the exception of my 1750 Wahoo! which I just upgraded to a 2012 Merc 4-stroke 90. I maintain only 2-stroke oil injected or pre-mix motors and use ethanol automotive fuel. The oldest motor in my collection is a 1987. Every 2-stroke I have will start and run as new right to redline. The storage ritual I use, is a manual fuel cutoff, or pull the fuel line and let them run dry. All of my boats (2-strokes are stored indoors) are not subjected to humidity or temp changes. The only time I've had a problem, is when I left fuel in the line, thinking I'd use it next week, and that turned into six months. Last year when we pulled apart my 1995 90 Merc to rebuild and modify, it looked new. I used only 92 octane and Merc Quicksilver oil. The starting ritual is to squirt the first cup of fuel in the line out, and connect. I've never used fuel stabilizer, and it's not uncommon for a boat of mine to sit unused for six months or longer. For eighteen years, on my 1995 Merc 90, I've averaged just under 5 hours use a year. So you can see the amount of time between starts, and the run hours on any motor I have is not significant. Keep posting, it's a great read! |
pcrussell50
posted 06-24-2013 12:44 AM ET (US)
Got the Alert 17 (special service Montauk) out at Lake Powell. Put the first long hard day on her since she I bought her from Brian/Fishnff back in February 2011. About a 45 mile round trip as part of a threesome of much bigger, newer, and somewhat faster boats. I had her at full throttle, all the way to the stop, for long long periods of time, or as water smoothness permitted. The Whaler did what they do well, give confidence. But this thread is about the motor. And it acquitted itself magnificently. It might as well have been a brand new EFI four stroke. I'm glad she tolerated the hard 5500+rpm running so well. Not to down on Mercury, but I was feeling reassured about the fact it is a really a Yamaha. That doesn't in the least make me less confident in the new Optimax ProXs I talked about in another thread for another boat. -Peter |
pcrussell50
posted 06-24-2013 12:48 AM ET (US)
Ooops, I forgot to mention that she just hit 887 hours on the meter. --Peter |
pcrussell50
posted 08-24-2013 06:05 PM ET (US)
Another "Whaler day" out on Lake Mead today. Left the sexy speedsters at home for this one. We put in at Temple Bar, about an hour's drive from our normal launch in Boulder City, NV. It was howling, and only upper 80's when it's normally above 100degF. But the wind was from a steady direction and there are plenty of coves facing all kinds of directions so we braved some rough stuff to find one in the lee of the wind. It's a few days till my birthday and what I wanted most is for my little girl (3 and a half), to catch her first fish today. And she did. A bluegill... which is exactly what we were going for, with a tiny piece of bologna on a teeeny tiny hook. Mission accomplished. :) The classic 17 (Alert 17), handled the rough stuff with aplomb, even though the return ride was wet, with the strong port-quartering headwind, the spray came back exactly right to drench us. No worries in a Whaler though.But this thread is about the motor, and the fact that there is nothing so say, says everything. Another day of easy, instant starts, and perfect, stumble-free, "might-as-well-be-EFI", operation. As a point of reference, the great running began for me, after a BIG de-carbon job performed by the Yamaha techs, during the 800 hour scheduled service. Yamaha tech's, because the powerhead is identical to the Yamaha F100. They knew it like the back of their hand. This motor is so Yamaha, that back when I thought the problem was the carburetors, I rebuilt them with Yamaha carb kits, in Yamaha packaging. Believe it or not, the Yamaha carb kits were actually _cheaper_ than the Mercury-branded carb kits. -Peter |
swist
posted 08-25-2013 08:24 AM ET (US)
Peter, you shouldn't post stuff like this. The motor will hear you....and then..... |
swist
posted 08-25-2013 08:28 AM ET (US)
pcrussell50
posted 11-14-2013 08:31 PM ET (US)
A quick update. This time after two and a half months of non-use, I took her out the other day just to get some heat in her oil. Nothing to report: Started right up, (again and again), and ran without a skip. Yet another "might as well be EFI" day of running with this carb motor. I do use Quickleen and Sta-Bil in every tank, but can't confirm or deny whether that has any value over a 75 day sit.-Peter |
posted 11-15-2013 10:57 AM ET (US)
Peter--Thanks for the update. It is great to hear that your carburetor motor is running well. Your experience with the carburetor motor is similar to mine. I had a big V6 with six carburetors. It started very easily. Its warm up circuits worked well. It ran and ran, never giving me a problem with the carburetors.It has been my opinion that in outboard engine applications the carburetor is just fine. Most of the operation of an outboard is at low elevations and in very moderate temperatures. The carburetor is a wonderful fuel-air mixing device in those conditions. The older outboard engines with electronic fuel injection were mostly very simple open-loop controlled injector systems, and they really did not have anything spectacularly better about them compared to a carburetor, other than they could be controlled electrically. The orifices in a carburetor are probably not much different in size than the ones in a fuel injector. Bad fuel can clog either of them. Too many people over-sell the benefit of simple fuel injection systems on outboard engines. The most important difference between carburetor fuel systems and electronic injection fuel systems seems to be in the closed fuel system of the electronic systems. The closed fuel system tends to prevent the evaporation of the fuel from the system. Carburetors that are left to sit a long time without use may have the gasoline evaporate, leading to some residue in the system. On my carburetor engine, I used to prime the fuel system before the boat was put away for temporary storage, to be sure to get the carburetor bowls filled with fuel. I also left the engine in an operating position, to prevent the fuel from spilling or draining from the carburetor bowls. If you leave a carburetor engine stored with it tilted to horizontal, most of the fuel drains from the carburetors. Using those storage methods, I could depend on my carburetor engine starting up beautifully after many weeks of not running. Also, I never tried to pull the fuel hose off and let the engine run until dry. That method might work on a pre-mix engine, but not on modern engines that try to automatically mix the oil and gasoline. You just wind up with much too rich oil mixture. Again, thanks for the update. It is encouraging to hear the older carburetor motor still runs like a champ. |
wezie
posted 02-25-2014 11:29 PM ET (US)
Peter, Info:Pick up tube on 2005 Merc 6 gallon tank dropped off. Engine runs poorly like that. Could burn it up I think. Second tank worked better. Screen on bottom looked great, plastic tube attached to that pick up is attached very well, But the tube is just pushed on the top fitting. Plastic expanded and dropped off. Added a clamp, and it works now. Have to do the other one before it falls off. Just an unending list of surprises. Good Luck to the Human Beings. |
fishinchips
posted 03-04-2014 11:32 AM ET (US)
When I had my 2003-170 montauk with the Mercury/Yamaha 90hp 4 stroke, I had carburator problems twice. Once I was able to fix it myself with carb cleaner and the other time I brought it into the shop to clean the entire carb. Since then I have always used Merc Quickleen and NO MORE PROBLEMS. When I sold the 170 earlier this year (2014), I purchased a bottle of Merc Quickleen and told the new owener to ALWAYS add when adding gas. I told him its a mandatory thing to do with this motor. Good Luck, Have fun and be safe.
Binkster
posted 03-05-2014 09:35 AM ET (US)
Peter, you have alot of patience with that Merc. I don't see any enjoyment working on modern outboards. rich |
swist
posted 03-05-2014 02:32 PM ET (US)
Peter and I both have a lot of patience with that engine. I too am convinced Quickleen is essential, despite what another thread in here keeps crowing about how great it is to use no additives. All engines are different and, as has been mentioned many times in this thread and others, for some design reason I don't understand, in this engine the carb passages are very small and clog easily. |
pcrussell50
posted 06-08-2014 02:20 PM ET (US)
Another update. Six straight months without even looking at the boat or motor, (new baby and some other stuff got in the way), and yesterday? Started right up like an EFI motor... As easily as if it had been used daily.Ever since I got the massive decarbonizing procedure, (the shop said the carbon buildup was extreme), this thing has run like a brand new EFI motor, not the maligned carb motor of it's reputation. Binks, I'm not sure what you mean by all the effort I'm putting into this. After I figured out what was wrong with it, (extreme carbon buildup in my case), it has run like a top ever since. Utterly reliable and trouble-free, Including after sitting for months and months at a time Yes, it is a four-stroke, but because it's carbureted, you can clean and balance the carbs yourself with an ordinary motorcycle balancing manometer. As a fellow carb guy, you should be able to relate to that. All my other motors are carb two-strokes. -Peter |
swist
posted 06-08-2014 03:08 PM ET (US)
Peter,My beast started up first try this season. So after 10 years I must be doing something right, maybe.
pcrussell50
posted 06-08-2014 07:57 PM ET (US)
Swist and wezie, my Mercaha carbed FourStroke bro's! Glad all's well with you guys too. With performance like this, I just can't justify repowering with something new. I just can't.-Peter |
wezie
posted 06-12-2014 09:44 AM ET (US)
Thanks for the update. This spring, mine decded to stutter between 1500 and 3000, before the high speed jets kick in. Lots of brown crud (dried out to dust) in fuel filter. I am guessiing some passed into somewhere. Drained and flushed bowls and changed filter. Fuel is fresh. Balanced carbs. Still same. The stutter gets worse the longer it is run, but runs fine abcve 3000.Do you run fuel out of yours when parked? I am very happy to hear from you and some successes. Maybe I will get this situation behind. Will let you know. I have about one more round of this continum in me. .? Did you ever find in-line filters at the fuel line carb connection, inside the fuel line.? My mercuy shop manual shows them. Looks lilke entire manifold has to be removed to get at them. That is my current unknown. Do I take the carbs and manifold off to look or just keep on trying. And then there are the dealers and mechanics., and $,$$$.??? One dealer already told me there are no little in-line filters. Nice to hear from you! John |
pcrussell50
posted 06-12-2014 10:51 AM ET (US)
Why yes, there are little inline filters located in the nipple on the carb where the fuel line attaches. They can fall out if you pull off the fuel line and don't notice.I wouldn't be afraid of pulling the manifold. Its super easy. Not even a 10 minute job.... Less if you are familiar. And it has one of those modern rubberized metal gaskets that you can reuse again and again. What do you use for balancing? The electronic balancer tool is over $1000. I use a motorcycle manometer from Motion Pro. The pro Yamaha mechanic who decarboned my motor and did the 800 hour service said I had it balanced perfectly. -Peter |
wezie
posted 06-12-2014 01:10 PM ET (US)
Honda Mechanic friend uses a 4 station gauge like Sealy Carb. He made the screw in adaptors for my carbs, by drilling metriic bolts and tapping. To remove manifolld, do carbs come with it? Do we need the little in-line filters? John |
pcrussell50
posted 06-12-2014 03:46 PM ET (US)
Yes, when you remove the manifold the carbs come with it. And they all stay nice and tight and together as opposed to flopping around hanging by hoses and wire rods. Easy peasy. As for the little strainers in the carb nipples? I can't say for sure how necessary they are, but I use them... Simply because the motor came with them. I will also add that in my adventures of multiple disassembly and cleaning of the carbs (before I found out they were not the problem in my case), I never found any crud in the little strainers. And I should add further that I run a water separating filter like a Racor, only mine is a budget brand. That filters first, then the little inline filter under the cowl, then the little individual strainers at each carb. I don't know how important the water separator is... It came with the boat when I bought it. -Peter |
pcrussell50
posted 06-12-2014 04:22 PM ET (US)
Pic of carbs on manifold, removed from engine: https://lh6.googleusercontent.com/-zwYaosP6IsU/Uoa8r-KPj-I/AAAAAAAAFl4/ A3oqHdey9IU/w452-h605-no/IMG_1724.JPG The aluminum manifold on the left is the part that bolts to the side of the engine block. I don't remember if you have remove the big black plastic plenum from the carbs to get to the bolts that hold the aluminum manifold to the block. Something in my memory tells me you can just remove the whole kit and kaboodle in one shot... something I didn't care about because I thought I needed to disassemble the carbs, when I was taking them off. -Peter
wezie
posted 06-12-2014 06:12 PM ET (US)
Thank s for the picture. I have the merc instructions, but that pict will get me going. Other than fuel blockage, I do not know what would cause the missing between 1500 And 3000. So here is the current plan. I will look check spark plugs. One more attempt to drain bowls and flush. Change the internal fuel filter. Add quicklean to new fuel and run. If no improvement, I will check those little filters and remoe what I need to get to them. Try again. This engine has maybe 300 to 500 hours. It has not been run hard, and maybe not hard enough. Do you believe a decarb would help? Or be a good step at this point, given the symptoms. Or does anything else come to mind?John |
pcrussell50
posted 06-12-2014 06:52 PM ET (US)
Mine has over 800 hours according to the hour meter. Reading some of the other threads regarding problems with this motor, a who have had mid-throttle misfires run it at that setting until it clears up. I had that symptom a little too before my decarbonizing job. The Yamaha dealer did it with what he called some super duper decarbonizer that only dealers can get.-Peter |
