  1989 Outrage 22 Restoration.
Author Topic:   1989 Outrage 22 Restoration.
EaglesPDX posted 04-30-2013 10:10 PM ET (US)   Profile for EaglesPDX
Near completion with the restoration of my 1989 Outrage 22:
New 150 HP Merc Four cycle
New 9.9 HP Merc Four Cycle
Replaces original 2 x 115 Optimax Two Cycles
Reduced total weight on transom by 150#
New Whaler teak pilot seat
Replaces original Whaler leaning post.
New Stryker T-Top
Replaces original William Miller Bimini with full front and rear canvas.
To do list:
Navy Blue front and side canvas with Eisenglass for T-top.
3/4 Rear bench seat to replace full width original Whaler seat. This provides access to the kicker motor and weighs 30 lbs less.
Front V lounge seating.
[Link to unviewable images deleted.]
Jeff posted 05-03-2013 08:52 AM ET (US)     Profile for Jeff  Send Email to Jeff
Since your facebook account it private, no one will be able to see the images unless they are friends with you. You are best off to use a Flicker or Photobucket site to host your images.
EaglesPDX posted 05-10-2013 07:15 PM ET (US)     Profile for EaglesPDX
http://www.flickr.com/photos/24867843@N07/8726407095/
After
http://www.flickr.com/photos/24867843@N07/8727515306/
Before
EaglesPDX posted 05-10-2013 07:16 PM ET (US)     Profile for EaglesPDX
So how do you make them viewable in the forum message?
sraab928 posted 05-10-2013 09:15 PM ET (US)     Profile for sraab928  Send Email to sraab928
There is a ubb code explanation just below your submit reply button when you are creating a post. Only use the url hyperlinking for pictures. You cannot imbed images here.
After Picture
Before Picture
outragesteve posted 05-11-2013 12:44 AM ET (US)     Profile for outragesteve  Send Email to outragesteve
I like your Styker T-Top. I'm looking to replace the Mills top on my 1990/22' Outrage/Standard console/leaning post/twin Yamaha 90-4s. How did you mount the lower side pieces to the floor? Did you screw them to the gas tank cap or through bolt w backing? How close to the console, and did you utilize the stan-offs and how many? I can not see if there are any pre-drilled holes to run wiring to the various mounts on the top. I went to the "Stryker" website and I'm quite impressed. Any other CWer's have input? Thanks, Steve
EaglesPDX posted 05-11-2013 08:51 AM ET (US)     Profile for EaglesPDX
The Stryker is just screwed to the flooring as was the original BW leaning post. There are two standoffs that you can customize that secure it to the console. It is very solid.
I didn't wire anything to it so I'm not sure about pre-drilled holes for wiring.
You can adjust how close you want it to the console side to side. I went with maximum walk around room.
Canvas shop that did my previous boats radar arche was very impressed with the welding and construction. He could not touch the price. He's working on a matching dark blue "phone booth" with Strataglass.
Neighbor has an 18 Outrage with Whaler T-top and the Stryker looks much better design and consruction wise. The original Whaler looks to be a lot of 2" and straight lines while the Stryker is 3" with a curve to it.
EaglesPDX posted 05-11-2013 05:09 PM ET (US)     Profile for EaglesPDX
Looked at the Stryker and there are no pre-drilled holes for wiring.
Comparing to original Whaler both have lower tubing of 2", the Whaler has skinnier 1"(?) tubing for the top itself while the Stryker is all 2" which looks better.
Looking at the Whaler T-tip, it looks to be screwed to the deck vs. back plates and bolts which would require taking the console out.
Buckda posted 05-12-2013 10:24 AM ET (US)     Profile for Buckda  Send Email to Buckda
First and foremost: nice spruce-up. The boat looks really good and that Mercury looks good on the back as well. I recently saw photos of a 25' Outrage with twin 150 Mercury Fourstroke engines and it looked really good as well.
For clarification and accuracy, you did not post photos of a boat with OptiMax engines. I believe those were 115 HP BlackMax engines, which are entirely different from the OptiMax engines. Just in case someone is looking to make comparisons between OptiMax and 4-stroke performance, etc. The BlackMax engines were solid performers for Mercury. I had a 150 BlackMax on my 18' Outrage before repowering her. However, they were standard issue, carburated 2-stroke engines, not the more advanced DFI OptiMax engines.
Just out of curiosity, why did you replace the leaning post with the RPS. I agree that a teak reversible pilot seat is very sharp looking, however, for functionality, I have found I really like the leaning post more than the RPS....which is why I am asking.
Dave
DeeVee posted 05-12-2013 02:09 PM ET (US)     Profile for DeeVee  Send Email to DeeVee
Eagle,
Did you the buy the SG300 or the folding SG600? If you have the folding top, do you like the way the folding mechanism works?
I have a large t-top on my Outrage 22 that has worked out well for me in most respects. Unfortunatley the t-top assembly makes the boat too tall to easily store in my garage. I like the way the SG600 can be folded down.
Your boat is looking very nice. I like the overall proportions of the Stryker top. It looks more appropriate on the 22 than the top on my boat. I have been thinking of making a change at some time in the future and may spring for one, though it would be down the road quite a ways.
Thank you,
Doug Vazquez
1989 Outrage 22
EaglesPDX posted 05-12-2013 06:49 PM ET (US)     Profile for EaglesPDX
[/quote]For clarification and accuracy, you did not post photos of a boat with OptiMax engines. I believe those were 115 HP BlackMax engines, which are entirely different from the OptiMax engines.[/quote]
They are whatever Mercury was selling in 1989, two cycle with internal 2 cycle oil tanks.
quote:
Why did you replace the leaning post with the RPS. I agree that a teak reversible pilot seat is very sharp looking, however, for functionality, I have found I really like the leaning post more than the RPS....which is why I am asking.
Leaning post was butt ugly and the seat acts as leaning post or seat with back rest. Teak adds a lot to the look. Really makes the boat look like a classic. Neighbor has a later model, 100% plastic 18' Outrage and the difference of teak vs. no teak is striking. Teak rear seat back, teak RPS, teak rod holders, teak console doors, teak bowsprit, teak inserts on the downrigger bases. If I could add the teak gunwales that were available, I would.
Previous owner had a customized metal storage center. I replaced that with a back facing cooler seat which is also my fish box. Hidden in front of the cooler is my tackle storage box. In front of the console, cooler seat adds two more seats. I'll be adding a three quarter width back seat, similar to the original full width seat and a bow v-cushion setup
Here's a pic showing the cooler seats.
http://www.flickr.com/photos/24867843@N07/8732501983/
EaglesPDX posted 05-12-2013 06:53 PM ET (US)     Profile for EaglesPDX
That is the SG300. If you trailer and need to get the top down every day, the SG600 would be the way to go. If it's a once a year storage, the SG300 has eight bolts and you can lift the top half off
Buckda posted 05-12-2013 07:24 PM ET (US)     Profile for Buckda  Send Email to Buckda
That makes more sense. The first year for the OptiMax was 1996, when Mercury introduced a 200 HP version of the motor.
bkovak posted 11-14-2013 07:19 PM ET (US)     Profile for bkovak  Send Email to bkovak
What kind of performance do you get with the 150 hp on a 22 Outrage hull? While it sounds somewhat underpowered, I have heard claims of 37-39 mph with a light load and propped right due to the lighter weight on the transom. I'm looking at a similar setup. Might be a low cost, low fuel consumption option for bay and river use for fishing. Do you still have the pictures you can send me? the links dont seem to work anymore. Thanks, Brian
jimh posted 11-15-2013 11:01 AM ET (US)     Profile for jimh  Send Email to jimh
[Note: the participant using the user-id EaglesPDX seems to have evaporated into thin air. He also appears to have removed his photo-library that he often linked to. I sent email to him, but it did not seem to elicit a reply.--jimh]
bkovak posted 11-15-2013 12:15 PM ET (US)     Profile for bkovak  Send Email to bkovak
Thanks Jim. Maybe he fell into that huge tank coffin in the floor of the 22 and some old foam soaked him up like water ...
Buckda posted 11-15-2013 01:45 PM ET (US)     Profile for Buckda  Send Email to Buckda
The very much debated performance figures for this boat are found in this thread:
http://continuouswave.com/ubb/Forum4/HTML/007886.html
bkovak posted 11-16-2013 06:21 AM ET (US)     Profile for bkovak  Send Email to bkovak
Great, thanks Buckda! Very interesting read. If I can get similar performance with a 150 to what is being reported, that would be a very nice option for the 22 Outrage. I was hoping for around 40 mph. 45+ is very impressive and almost unbelievable! The mid range fuel burn reported is also quite efficient as well. Brian
Plotman posted 11-19-2013 11:17 PM ET (US)     Profile for Plotman  Send Email to Plotman
I can get 37 with a light load in my 22 Outrage with a single 130 yamaha.
