ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Repairs/Mods OUTRAGE 22; Re-wiring Sidelight Lamps
Author | Topic: OUTRAGE 22; Re-wiring Sidelight Lamps |
stayinstrewn |
posted 07-27-2013 01:40 PM ET (US)
This winter I will need to replace the wiring to my [sidelight lamps on a Boston Whaler OUTRAGE 22]. The available wire is so short I can't get a chaser on from the bow, nor can I pull it out from the bow.. Do the lines run through molded tunnels? Or, out the hull and under the rub rail? If they go through a tunnel, I presume it's fairly easy to get a wire chase down to lead new ones. Any thoughts? Any help would be great. |
posted 07-27-2013 05:32 PM ET (US)
Questions about repairing the wiring to the sidelights at the bow are frequently asked. See the answer in the FAQ: http://continuouswave.com/whaler/reference/FAQ/#Q4 If you need more advice, ask a follow-up question in this thread. |
