  Mercury 115 In-line; No Spark
Author Topic:   Mercury 115 In-line; No Spark
mercfan posted 10-22-2013 10:18 AM ET (US)   Profile for mercfan   Send Email to mercfan
My 1988 [Mercury 115-HP in-line six-cylinder outboard engine, also known as a] Tower of Power has spark on cylinders 1, 4, and 6, but no spark on cylinders 2, 3, and 5. I swapped all coils around and they are all good. I replaced both switch boxes and still have the same problem. Any ideas?
jimh posted 10-22-2013 10:51 AM ET (US)     Profile for jimh  Send Email to jimh
[Moved to REPAIRS/MODS.]
jimh posted 10-22-2013 12:18 PM ET (US)     Profile for jimh  Send Email to jimh
The usual arrangement of a spark ignition system is to get a timing pulse from a special coil or coils arranged on the permanent magnet alternator coil assembly, sometimes referred to generically as a stator (because it is a stationary coil, that is, it is not rotating with the engine crankshaft). It may be that there are two timing coils on your engine, one associated with the cylinders that are firing and one associated with the cylinders that are not firing, and a defect in one coil, the one associated with the cylinders that are not firing, would explain your situation.
L H G posted 10-22-2013 01:33 PM ET (US)     Profile for L H G
Your engine has an ignition system that is alternator driven (ADI) with distributor-less capacitor discharge. With coils and switchboxes both testing OK, your problem is either the stator assembly or the trigger assembly. Both conduct AC voltage to the switchboxes. The trigger conducts voltage to an electronic switch in the switchbox, and this switch then discharges the rectified and stored scapacitor voltage (from the stator) into the ignition coils.
You most likely are going to have to bring it to a servicing shop for diagnosis and replacement of the non-performing component. Flywheel removal is necessary.
I'm guessing your problem is the trigger assembly, but it's only a guess.
Be sure your water pump impeller is good. On these L-6's, the most common reason for failure of these under flywheel mounted components is excess heat coming from the top cylinders on this tall engine. You need a good impeller to get the cooling water up there.
outragesteve posted 10-22-2013 10:27 PM ET (US)     Profile for outragesteve  Send Email to outragesteve
Larry's guess is probably good! If one of the switch boxes goes, you loose spark on 1-3 or 4-6. When a trigger fails, you loose spark on 3 non-consecutive cylinders, like you are describing. Good luck!
Tom W Clark posted 10-22-2013 10:34 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
The ignition system on my 1989 Mercury V-6s is the same as this motor. I went through the same troubleshooting process this summer and the culprit ended up being the stator. Since having the stator replaced, the motor has been running well again.
jimh posted 10-23-2013 12:34 AM ET (US)     Profile for jimh  Send Email to jimh
I believe that Larry's advice follows mine, and is confirmed by Tom. That is three votes for a coil assembly providing a timing pulse to the ignition system as the culprit.
Do you have the service manual for the engine? If you plan to any sort of real work on your engine you will find that investing in the service manual, the actual factory published manual, will be a good return.
These old-fashioned capacitor discharge ignitions have mostly gone away, replaced by inductive discharge ignition systems which provide longer and better spark, but in the 1970's the capacitor discharge was the modern technology. Now, 40-years later, it is a bit of an anachronism, but it still gets used on some low-tech engines.
L H G posted 10-23-2013 01:58 AM ET (US)     Profile for L H G
Mercury's ADI was first used on the in-line 6's 1980-1988 model years. So I guess it's 80's technology, now 33 years old.
[Now changed topic: what engines can run with these old Mercury engines when the old Mercury engines are actually running:] As far as I can tell, the only 2013 115Hp engine that can run with one of these ported piston classic Mercs is the 123HP Optimax 115 ProXS. And it is 70 pounds heavier.
tom976 posted 10-23-2013 10:03 AM ET (US)     Profile for tom976  Send Email to tom976
I miss the old thunderbolt ignition systems in those old inline 6's Easy to work on and lots of parts available.
jimh posted 10-26-2013 11:14 AM ET (US)     Profile for jimh  Send Email to jimh
[Re Capacitor Discharge Ignition history and developement:] There is a good article on capacitor-discharge ignition systems in Wikipedia. It traces the development from the 1890's to the 1960's when they became practical in cars due to the development of the silicon-controlled rectifier.
In recent years the use of capacitor discharge ignitions on outboard engines has decreased because of the lean fuel-air mixtures. A lean fuel-air mixture is harder to ignite. The extremely short-duration spark from a capacitor-discharge ignition often fails to ignite the fuel-air mixture in a modern, lean-burning engine. Inductive discharge ignitions provide longer spark duration which is better for igniting lean mixtures. Most outboard engines now use inductive discharge ignitions to take advantage of the long-duration spark they provide.
The capacitor discharge ignition was useful for getting fouled plugs to fire because of a very fast rise time on the spark voltage produced. In modern engines there is much less occurrence of fouled plugs, as the fuel mixture is usually very well controlled. This is in contrast to some old two-stroke-cycle engine where fuel was poured into the cylinders.
[On Larry's new topic: what modern engines can run with the old Mercury engines:] These old Mercury in-line six-cylinder engines are still popular with the go-fast crowd who like to hop-up their outboard engines, but they are not very practical engines for modern use. The cowlings are very tall. This makes them awkward for use on fishing boats. The fuel economy is typical for a two-sroke-cycle engine--awful. If you want to cruise around with an anachronistic outboard motor from a period where fuel consumption and exhaust emission were of no concern, they're the ideal motor, if you can keep them running. As evidenced here, the electricals on these old Mercury outboard engines seem to be a constant problem. I think there are more articles seeking advice about Mercury "stators" and "switch boxes" than any other topic, which is perhaps a benchmark of the unreliability of those components.
As for the notion of being "able to run with" an obsolete Mercury in-line six-cylinder engine, I am not sure exactly what advantage accrues. In my boating experience I do not find myself attempting to drag race other boats or running contests to see which boat has the ultimate top speed, so whether or not one can "run with" one of these old engines seems to be something of an obscure concern for most Boston Whaler owners. As for the speculation that only some other Mercury outboard engine could possible keep pace, well, that is just too darn bad for me, I guess. I am not sure, even if that were true, it would sway me to buy an Optimax. Finally, in the context of this discussion, I don't believe this old Mercury outboard is even running with half its cylinders not working, so it should not be too hard to "run with" it at this stage.
Tom W Clark posted 10-26-2013 12:14 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Jim -- I am sure mercfan finds your [comments--which Tom characterized as being negative and harsh] very helpful. [Tom--perhaps as useful as he finds Larry's new topic about what engines can run with this old Mercury. He will have to get it started to find out.--jimh]
Binkster posted 10-26-2013 03:45 PM ET (US)     Profile for Binkster  Send Email to Binkster
I always thought that the inline six Mercs were the pinnacle of all outboard motors. I would get a 90 or a 115 and mount it on my 15 footer if it wasn't for my better(smarter) half. One thing jimh left out is that they are also loud, especially when mounted in pairs like I had on my 24 foot xxxxxx. Its an adrenaline rush when running wide open.
(xxxxxx-in order to hide my embarrassment.)
rich
jimh posted 10-26-2013 07:33 PM ET (US)     Profile for jimh  Send Email to jimh
Tom--Since mercfan's engine probably won't even start, I don't know how much it matters that in Larry's opinion there is no other outboard made today that can keep up with it. But I wish mercfan good luck with his repair. There are so many articles in REPAIRS/MODS about bad stators or other electrical problems with these older Mercury engines that I probably should add an answer about them to the FAQ.
I don't know exactly what special benefit there is to learn that this engine is or was or continues to be the greatest outboard engine ever made in the opinion of at least two readers. When it doesn't run and you can't figure out why, it takes a bit of the luster off them from being the engine nothing else can run with.
jimh posted 10-26-2013 07:37 PM ET (US)     Profile for jimh  Send Email to jimh
Binkster--thank you, for the reminder about the noise. For a long time people used to admire quiet engines, but, as I noted a while ago, there has been a complete reversal about noise. At least, according to some, there has been a complete reversal, and now loud engines are effusively praised. If this Mercury engine is a loud engine then we can expect it to be effusively praised now, because there is a new cadre of outboard engine owners who have proclaimed that loud is IN.
I guess this engine hits all the high marks: loud, bad fuel economy, lots of smoke in the exhaust. They're the new benchmarks for what is good in an outboard engine. But I hope you get it running again. If you ever decide to sell it you can probably find some old-timer who wants to buy it so he can re-live the 1980's.
jimh posted 10-26-2013 11:18 PM ET (US)     Profile for jimh  Send Email to jimh
I have about 50-years of hand-on experience with electronics, and it surprises me that there are so many reports of problems with the stator of a permanent magnet alternator, as we read about, for example, here in this attempt to diagnose the problem that keeps this Mercury outboard from operating properly. A stator is a coil that does not move. It is a passive device. There are no active electronics in the stator; it is just wire. Why does this piece of wire, wound into a coil form, go bad so often on an outboard engine, and why, specifically, on these older Mercury outboard engines, not just the in-line six-cylinder but many other configurations?
I can see several ways the coil could become damaged. First, there could be mechanical damage to the wire. Vibration from the engine causes it to repeatedly flex and eventually to break. Or, some moving component hits the wire repeatedly and it breaks. These coils usually use a solid wire, so vibration could be a cause. A winding might sag and be struck by the rotor of the alternator. Next, there could be a loss of insulation. Typically these coils are wound with a wire whose insulation is just a coating of a special enamel or varnish (sometimes called Formvar). If there is too much heat, the insulation could melt away. Without insulation the turns of the coil begin to short out to each other. Shorted turns in a coil in a strong magnetic field are a big problem, as they tend to generate more current and heat, leading to more problems. A third means of damaging a stator might be just from too much operating current being generated for the windings. If the coil winding are not made with a conductor of sufficiently large size, over time the operating current could heat the conductors and cause their resistance to rise. Copper's resistance rises with temperature.
Of course, the cause of high temperature is probably most likely from the engine. With the stator at the top of the engine and under the flywheel, it is in a natural position to collect engine heat and become hot. If the engine is chronically running very hot, the stator will be running very hot, too.
One solution to the problem of heat getting to the stator coil of an outboard engine is to design the flywheel so that it acts like a fan and draws cooling air into the region of the coil. On modern outboard engines this is exactly the approach used. The stator is provided with some air circulation from a fan built into the flywheel. This should help keep it cool and avoid the sort of damage from heat I describe above.
L H G posted 10-30-2013 07:17 PM ET (US)     Profile for L H G
Here is another classic Whaler owner that really understands what owning one of these Ribsides is all about.
A beautiful rig with a same period engine: (makes no difference whether it is a ported piston Merc "tower" or an OMC "bubble back" V-4 135). Either will accomplish the same thing.
https://picasaweb.google.com/116357140938494828881/ 1971BostonWhalerOutrageIIRibside#5757194806860553842
Actually, these Mercury sixes get rather decent fuel economy. On mine, with (supposedly wasteful) twins, I consistently get at least 2.7 MPG at 30 MPH cruise on the Ribside. Those figures are from an on deck measured Tempo 12 gallon tank and GPS distance measurement. I think it's quite good. Based on my own considerable experience with both the engine and hull, I'm sure this rig pictured would be getting over 3.0 MPG. and maybe a top speed approaching 42 MPH. Not bad.
I haven't been able to get an accurate reading yet on my Montauk powered by this engine, but it is looking like 5.0 MPG at cruise. The engine hardly uses any fuel at all compared to what my other boats use. A 3-star Optimax 115 might give me an even better 7.0 MPG, but for the cost, I won't live long enough to save the 9 grand in fuel between 5 and 7 MPG. It's relatively insignificant to my wallet. And then I'd have a modern engine on a classic boat, ruining the Ribside's totally classic appeal.
Got to love these old 2-strokes, whether they be Mercury OMC or Yamaha.
EyeDock posted 10-30-2013 09:23 PM ET (US)     Profile for EyeDock  Send Email to EyeDock
I had a similar 115 Merc (1992) on my previous 17Montauk.
Any ignition issue merits consideration of the stator.
jimh posted 10-30-2013 10:25 PM ET (US)     Profile for jimh  Send Email to jimh
When you replace the stator on one of these old-timer engines, is the replacement part from the OEM, Mercury, or are after-market stators typically used? The reason I ask is the apparently rather high failure rate of the OEM part might suggest that an aftermarket part might offer an improvement.
In my discussion of possible causes of failure of a passive electrical component like a stator, I failed to include on obvious cause of poor reliability: poor quality of the original component. Sometimes the manufacturer learns that the original part was not sufficiently robust and upgrades the design. Other times the OEM keeps making the same part, and the aftermarket parts offer improvements.
Which source is recommended for replacement of a Mercury stator for one of these in-line six-cylinder engines: Mercury or after-market?
L H G posted 10-30-2013 11:38 PM ET (US)     Profile for L H G
My experience is that, like automobiles, the problem is almost always the use of lower priced after market components. After a problem occurs, and the aftermarket part is discovered, they always say they did it to save "you" money. They actually used them either because they could get one quickly (to get you back on the the water the fastest), or to increase their own profit.
Some components of these classic engines are no longer available OEM (such as a flywheel, new blocks or new carbs), but in the case of the Merc sixes, things like stators, triggers and switchboxes still are, as there are still a LOT of these engines out there and Mercury keeps them available. I don't have much information on the old OMC classics, but for the four I have had repaired in the last 4 years, they had no problem finding the parts.
jimh posted 10-31-2013 03:23 PM ET (US)     Profile for jimh  Send Email to jimh
I recommend you check out carefully the offerings from CDI. The CDI operation has an excellent reputation, from what information sources I have, and it is even mentioned that they are the real OEM for some replacement parts sold by the engine manufacturers. I can easily see that as the real truth. I tend to wonder about outboard engine manufacturers continuing to make their own repair parts for 30-year old engines, and especially electrical parts, which were often produced by sub-contractors even during initial production of older engines.
Check out CDI at
http://www.cdielectronics.com/about/
I believe that CDI makes all of their own products in the USA. Many electrical parts sold by Brunswick under their Mercury brand carry Made in Mexico stickers. I see them on eBay pictures of Mercury parts.
Also, you may find a lot of good diagnostic information in the information that CDI has on their website. The installation instructions for their Mercury stator part for a 1983 in-line six-cylinder is filled with information about diagnostic testing with simple test gear to determine if the stator is in proper working condition. I would exploit that resource of information.
Also, I think the hardest part of the stator replacement will be getting the flywheel nut loose. If the nut has been on for 30-years, it may be reluctant to come loose.
jimh posted 10-31-2013 03:31 PM ET (US)     Profile for jimh  Send Email to jimh
Another source of replacement electrical parts for older outboard engines is
http://www.outboardignition.com/
This vendor says:
quote:
While OEM outboard boat motor ignition parts are fair in quality, we offer an aftermarket brand of stator, power pack, switch box, trigger, timer base, coil, regulator, rectifier, wire harness, etc. parts manufactured by CDI Electronics, in which have redesigned their boat parts over the OEM counterparts and made them better. Actually, "better" is an understatement. Read below to find out what we mean and why you should consider replacing your troubled outboard motor ignition parts with these parts instead of the less reliable OEM parts.
They also offer up to five-year warranty on these replacement parts.
I tend to believe these statements that the quality of the parts has been improved. It would surprise me to learn that an outboard engine manufacturer would significantly change the product specifications for a part for a 30-year-old engine and re-tool to make a new part just to offer an improved replacement part. It seems more the province of the aftermarket part manufacturer to make improvements, particularly in parts for 30-year-old engines.
I should also mention that CDI has a technical support telephone line. You may find that calling them could be a way to get some assistance with the stator diagnosis.
jimh posted 11-01-2013 11:57 AM ET (US)     Profile for jimh  Send Email to jimh
On the topic of Capacitor Discharge Ignition (CDI):
One feature of the CDI was the ability to produce really high voltage spark. However, this also creates a problem: how to contain that really high voltage. I recall that our family car back in the 1970's was a Chrysler with a big V8 engine that had CDI. The car was powerful, but it had this nasty habit of not being able to start in really damp, high humidity conditions. I remember getting stranded one foggy wet night when it would not start. I think the spark voltage was so high that it was being bled away on the wet ignition wires. That is the same sort of thing that could occur in a marine environment. Moisture could be a cause of problems in a CDI system with very high voltage. Also, older spark plug wires can decay to the point where they cannot handle the high voltage of the CDI.
In lean combustion with CDI, it is common to use multiple spark firing to try to insure the lean mixture is combusted. This can lead to spark plug erosion. The CDI may produce two, three, or more fires on each cycle to give the best chance of a lean fuel mixture ignited from the spark.
I think these old Mercury engines use the so-called gapless spark plugs. These plugs have a wide spark gap from a center electrode to a surrounding ring, and are often used in old two-stroke-power-cycle engines with really high voltage CDI because they tend to not become fouled. The ultra-high spark voltage can jump the wide radial gap. You never see those spark plugs used in modern engines.
Modern engines use conventional gap plugs, with rather tight gaps, and use inductive discharge ignition to create longer spark times. This produces fewer misfires of lean mixtures. With modern spark plug electrodes using rare-earth metals, spark gap erosion is a thing of the past, and spark plugs last for years and years.
Binkster posted 11-01-2013 09:31 PM ET (US)     Profile for Binkster  Send Email to Binkster
jimh, with your articles in this thread you have revived my interest in finding a mid/late 1980's 4 cylinder 50 hp Merc for my soon to be completed 15 footer. It would have to be an original low hour fresh water motor from the Great lakes area. My local Merc dealer has to be one of the smallest in the country. Its a two man operation, the owner who does the repair work and his helper. He carries no new stock, if you want a new one he has to order it. I have known him for years, and he still works on old outboards. With all those better than new OEM electrical parts floating around, I could have him rewire the whole engine and still not have too much money in it.
rich
jimh posted 11-02-2013 01:09 AM ET (US)     Profile for jimh  Send Email to jimh
Rich--on my 1976 Boston Whaler SPORT 15 there was a beautiful Mercury 500, four-cylinder two-stroke-power-cycle outboard engine with an early CDI ignition. I sold it quite a while ago to a local fellow, and, now, very ironically, he and I both work at the same place. That 1976 Mercury 500 is still running like a fine Swiss watch. I don't think he has had to have any work done on it since I sold it to him. They are great little engines, about 44-cubic-inch displacement.
