  OMS Pump on 1993 Johnson 150-HP
Author Topic:   OMS Pump on 1993 Johnson 150-HP
gord ross posted 11-01-2013 03:38 PM ET (US)   Profile for gord ross   Send Email to gord ross
I had a new OMS pump by BRP put in my 1993 Johnson 150-HP outboard engine at the same time as a new power head, late in 2012. The pump worked right from the start and is still pumping, but it is pumping too much oil. It burns the whole reservoir with one tank of gas, 17-gallons. Is there a fix for this problem? Maybe a smaller pulse limiter? Thank You
jimh posted 11-02-2013 01:13 AM ET (US)     Profile for jimh  Send Email to jimh
Something sounds awry. The OMS should use oil in a ratio of about 1:50 to gasoline. Typically if there is too much oil being used, there is a problem in the pump, perhaps a faulty seal or diaphragm. Have you read:
http://continuouswave.com/whaler/reference/VRO.html
The above offers some diagnostic advice for pump malfunction symptoms.
