posted 11-07-2013 05:26 PM ET (US)
My mechanic pointed out that it appears that the waterline on my 2004 Montauk 170 has risen maybe an inch since the boat was new. Given that slow a rate (1/8" per year) I never really noticed, although now that he mentions it, I did observe that the swim platform, which barely cleared the water when the boat was new, is now right at the water level. And there is a line of crud where the bottom paint is not quite making it to the waterline.I have not noticed any difference in performance, although if you lose just a few percent every year, you may not notice. And with a painted hull, and extra accessories (26 gal tank and heavy full width rear bench seat, it is hard to compare my numbers to the ones Whaler publishes).
The boat is moored all Summer. Sounds like maybe my foam is getting wet, although the only holes in the hull are those from the factory. The theory is that lack of watertightness is rarely noticed on that model as 90% of them are trailered.
What do I do? Someone said drill same holes, let it dry out all winter, and epoxy them closed. Is this a good idea? How many holes, how big, and where, what kind of epoxy?
I find it hard to believe that a hull that is supposed to last a lifetime has an unfixable problem here.
