  Converting OMC Side-mount Controls
Author Topic:   Converting OMC Side-mount Controls
skred posted 11-13-2013 12:04 PM ET (US)   Profile for skred   Send Email to skred
I have a 1981 Johnson side mount control. Is this OEM control convertible to attach as a left-hand control as well as a right-hand control?
jimh posted 11-13-2013 02:43 PM ET (US)     Profile for jimh  Send Email to jimh
Check on SHOP.EVINRUDE.COM under the OB ACCESSORIES category. You will find 1981 side mount control is listed. I don't see in the exploded view diagram that there are alternative housings. It is difficult to link directly to the diagram because it is presented in a frame on another page. You should be able to navigate to it without too much difficulty from the top page.
skred posted 11-13-2013 03:20 PM ET (US)     Profile for skred  Send Email to skred
Thanks, Jim. Checked it out - there's no accessory or adapter available. I'm going to stick with the standard side mount I have, since anything new (i.e., binnacle mount) is just way too pricey.
contender posted 11-13-2013 07:55 PM ET (US)     Profile for contender  Send Email to contender
If you are talking about the old simplex dual level evinrude control box then yes you can convert it to a left side mount.
seahorse posted 11-14-2013 07:14 AM ET (US)     Profile for seahorse  Send Email to seahorse
To reverse mount the regular control box that came with the motor, just remove the throttle lever and its index plate and install on the opposite side of the box.
This was done often on center console boats when the side mount control was used instead of a binnacle style.
skred posted 11-14-2013 01:23 PM ET (US)     Profile for skred  Send Email to skred
Thanks. I'll see if that works. I wanted to mount it on the right side of a center console if I decided to install a center console. My control is the single-lever OMC type with the safety lanyard cutoff. It might be that the control box is newer and can't be reversed. If so, I'll just mount it conventionally on the starboard riser board.
Binkster posted 11-15-2013 11:48 AM ET (US)     Profile for Binkster  Send Email to Binkster
Why not trade it in at the marine boneyard for a binnacle mount control box.
rich
skred posted 11-15-2013 11:27 PM ET (US)     Profile for skred  Send Email to skred
Rich, I'm working on the swap angle, too. Not much luck so far...
