  Roll and Tipping my 15 with Interlux
Author Topic:   Roll and Tipping my 15 with Interlux
littlehandegan posted 11-17-2013 11:51 PM ET (US)   Profile for littlehandegan   Send Email to littlehandegan
Looking to roll and tip my 1976 15 Whaler.
Interested to see what others have done, any tips or instructions or must reads?
dg22 posted 11-19-2013 12:24 PM ET (US)     Profile for dg22  Send Email to dg22
I found it worked best when I had someone help me do the tip part. I would roll the paint on with a foam roller and my daughter followed with a foam brush to tip. It looked very close to a sprayed paint job when we did it that way. Mind you, the key is the prep work before painting. If your surface is smooth, your paint job will look good. Follow the instructions closely on the paint can.
Best of luck.
17 bodega posted 11-22-2013 02:17 AM ET (US)     Profile for 17 bodega  Send Email to 17 bodega
Go look on Jamestown Distributors website for some great you tube style videos on rolling and tipping techniques.
http://www.youtube.com/watch?v=Gjyzc4c9JnE
it's a simple guideline...
andygere posted 11-22-2013 02:26 PM ET (US)     Profile for andygere  Send Email to andygere
Make sure you use a good high-fill primer before hand, and properly sand through fine enough courses to remove all scratches. I did an Interlux roll and tip job on a sea kayak that I built, and it came out very glossy and nice. I had a lot of time invested in prep, and it paid off. As I recall, after sanding, filling and fairing all the fiberglass work, I had at least two or three rounds of the high fill primmer, with wet sanding in between, before all the scratches were out. I second the advice to have a second person doing the tipping. Also, have several roller frames set up with good quality foam rollers so that you can change rollers without delay. The key is to keep a wet edge, and there's no time for changing out rollers! Even the good rollers tend to get saturated with paint and get saggy, and this will ruin the job if you don't have a fresh one ready to go.
