| Author | Topic: From Roller To Bunk Trailer Advice |
| onlyawhaler |
Up here in Utah everything is a painted trailer. I have a single axle galvanized roller Shorelander on my 1999 20 Outrage that came with it when I purchased it years ago from back east. I have never been keen on the trailer that it came because of rollers and the discussions I have read here on rollers and Whalers and I would prefer dual axles for travel safety reasons. Out of nowhere, a local person appeared with 18 barely used 2013 Shorelanders that are galvanized galvanized Shorelanders for sale for a good price. He is down to his last one in a single week. Very suprising. They were bought by Lake Powel for a rental fleet that came with Champion boats on them and they aren't needed so they went up for sale and this local person bought all of them I have reserved one to fit to my boat. I have checked with Shorelander to be sure it will fit my boat and it appears its a perfect match. I will use a local boat shop to make the switch. There are no keel rollers on this trailer except for the very back and the very front. Its the style where the entire boat is supported by 4 bunks The local boat shop is unsure on a Whaler where the support on the 4 bunks should rest and the position of the bunks on the transom area as Whalers are scare around here. I am unsure as well. My two part question is on our Whalers with the UniBond construction, should the 4 carpeted bunks extend to the very edge of the rear transom or extend beyond the transom edge so they are showing or not reach it and stay further underneath for support reasons? I am also unsure as to how to direct them to position the bunks in the flat areas with emphasis to position them more out the edges of the sides or further in. Thanks for any feedback Sterling |
| andygere |
Here's a few photos of the 4-bunk EZ Loader my Outrage 22 used to sit on. It should give you an idea of how it was set up. The carpeted bunks extended to the edge of the transom. http://img.photobucket.com/albums/v408/andygere/EZ%20Loader%20Trailer/ IMG_1569_zps5951a237.jpg http://img.photobucket.com/albums/v408/andygere/EZ%20Loader%20Trailer/ IMG_1566_zps6f77f280.jpg http://img.photobucket.com/albums/v408/andygere/EZ%20Loader%20Trailer/ IMG_1565_zps1cd92e6b.jpg http://img.photobucket.com/albums/v408/andygere/2007%20Rendezvous/rig. jpg |
My Boston Whaler boat, like thousands and thousands of others, has been resting on a bunk trailer for decades. The four bunks are arranged so that the innermost two bunks are close to the keel. The outboard bunks are positioned so that they are inboard of the runners of the outer sponsons. When the boat is in its normal position on the trailer, the ends of the bunks are coincident with the end of the boat transom, that is, the transom is completely resting on the bunks. There is no reason why one ought to let the transom extend rearward on the trailer beyond the bunks, nor is there any advantage in particular to pulling the boat so far onto the trailer that the bunks extend beyond the transom, unless you want to use minimize the overall length of the trailer for some reason, such as to fit into a garage. Some trailers are set up with the outer bunks positioned to rest just inside the runners. I see two problems with that configuration: --there is usually a drain with a cover which will be located close to the runners, and if the bunk is positioned close to the runner there will be a tendency for the drain cover to become crushed by the weight of the hull pushing in onto the bunks; this also creates a pressure point if the drain cover is carrying the hull weight onto the bunk; and --the boat must be positioned laterally on the trailer with great care or it can end up with one of the runners sitting on the bunk; that is not a stable position. It also reduces the area of the hull which is bearing the weight of the boat. If you really want to spread the bunks to the inside width of the hull's runners, you could cut away part of the bunk that will be under the drain outlet and cover. If you create a relief in that area from the drain to the rear end of the bunk, you can prevent the drain from getting crushed. This will complicate the bunk construction slightly. If you make the bunks fit very tightly inside the runners, it may be harder to get the boat aligned for loading on the trailer. A looser fit is probably easier to work with when loading. I have towed my Boston Whaler boats on bunk trailers for about 80,000-miles. (This figure is based on the Odometer of my truck, which is used only for towing the boats, and has rolled up about 90,000-miles since I bought the truck used in 2002.) Based on what I have seen in 80,000-miles of towing, if the boat is loaded on the bunk trailer with a slight offset from perfectly centered, the travel over the highway with its usual bumps and motion will tend to allow the boat to center itself on the bunks by the time I arrive at my destination. I should mention that I usually drive about 250-miles at the minimum to get between a launch ramp and home. I find that if I stop on the highway at a rest area and check the tie-downs at the stern of the boat to the trailer, I will see that one has loosened a bit and one had increased in tension, due to the boat centering itself on the bunks. I should also mention that I use rope for the tie-downs, not nylon straps. I suppose that if one were to tie-down the boat with nylon straps under a lot of tension that it would limit the movement of the boat on the trailer. I prefer to use rope, which has more stretch, and this allows the boat to become more or less perfectly centered on the bunks by the end of my highway towing. I usually adjust the tension in the tie-downs when the boat has centered itself. Many trailers have a vestigial keel roller at the rearmost crossmember. That is just to deflect the boat's keel during initial loading, should the boat trailer come into contact with the keel. Most of the time those rollers will end up far below the keel when the boat is loaded. It is useful to have keel rollers in the forward part of the trailer. I explain: There should be a keel roller in the very forward part of the trailer positioned near the bow so that when the boat is in its resting position on the trailer the bow will be supported by the keel roller. This is very useful when loading or launching to prevent the bow from dropping suddenly when coming out of the winch stand rests. There should be keel rollers on the cross member at the forward end of the bunks. Usually at this station the keel will be within a reasonable distance to the crossmember so that it can be supported by keel rollers without having to elevate the keel rollers from the crossmember excessively. The height of the fenders and the fit of the boat between them will set the overall height of the boat on the trailer. Set this height to be as low as possible for many reasons: --a low height will make the center of gravity of the trailer and boat rig lower, which is good for stability when towing --a low height will decrease the depth of immersion of the trailer needed to launch or load the boat, which can be very helpful if the launching ramp is short, shallow, or otherwise marginal; and --a low height will make it easier to climb into the boat when on the trailer, something that is always necessary and, if the boat is really high, can be hard to accomplish. I recently went to a great deal of trouble and some expense to lower my boat on my trailer about 2-inches. It was worth the effort, if for nothing else, to make it easier to step into the boat from the top of the trailer fender. The boat also launches and loads with less immersion of the trailer. The clearance between the fender top and the hull can be set rather close. As I recall, on Don Mac's OUTRAGE the hull is sitting about 0.5-inch above the trailer. On my set-up, the boat is still about 1.5 to 2-inch above the fender. |
| onlyawhaler |
Thanks very much for the advice on the change over on the new trailer from rollers to bunks. Very much appreciated It worked out well I think. It will be spring before I put any miles on it, but it was a great upgrade for the cost. It was a bit tricky with bunk spacing with the two fish box drain holes that had clam shells on the bottom and getting those between the bunks so they would not be crushed. I didn't really have to worry about that with the roller trailer with its large softer rollers before. On that note, I noticed some slight dimpling on the running surface of the Whaler from the rollers that I was concerned in seeing. Even the larger softer rollers can dimple a Whaler I have learned and the road miles going to Lake Powell have probably contributed to it. Thanks again Sterling |
| Chuck Tribolet |
I don't think anybody answered your question about where the bunks should end at the stern. Ans: They should extend JUST (1/2"?) beyond the transom. The transom is the strongest part of the boat, and has several hundred pounds of outboard sitting on it, so you want the transom supported. By having the bunks extend just beyond the transom means it's still supported when your brother-in-law doesn't quite crank the boat all the way on.
| sjp2 |
Do you guys sink your trailers (until the water is almost over the back wheel) and basically float the boat on? Or, r do you winch the boat on, like I do with my aluminium boat, only getting half the trailer wheel wet? The reason for asking was that I did that with my recently bought 13, and I soon found a soft spot in the keel. The trailer has three keel rollers. I have since changed the back and middle rollers to doubles and reinforced 6 feet of the keel. [This thread has been edited to conform to our minimal style requirements regarding capitalization of the initial letter of the initial word of a sentence.--jimh] |
| swist |
That has to depend on the weight and buoyancy of the boat and the slope of the ramp. My M170 will float off the trailer without the latter getting too far under water. I like to find the position with the least amount of trailer under water that allows it to be winched up easily (or backed off under power or with a strong push). |
On a bunk trailer the boat's weight is resting on the bunks. At the angle of incline found on most ramps (about 8-degrees), and when the bunks and boat are dry, typically there will be too much friction between the boat hull and the bunk carpet surface for the boat to slide off. Many years of launching with a bunk trailer at many different boat launch ramp sites has shown me that most of the time the trailer has to be backed down the ramp until the aft portion of the hull is immersed in water at least to a depth equal to its normal waterline mark, that is, so there is some buoyant force exerted upward on the aft part of the boat, reducing the load on the bunks. On my trailer I have white tall PVC tube guide posts, and on these posts I have place a mark (with black electrical tape) that is at the same level as the boat hull's water line. When the trailer is immersed to the point that this mark is at or just below the water, then I know the weight of the hull on the aft part of the trailer has been reduced by the buoyant forces. If I stop backing the trailer at this point, the momentum of the boat moving backwards is usually sufficient for it to slide off the bunks. For this reason I usually need an assistant to stop the boat's sternway, otherwise it would float into the lake. (I have launched solo, and in that case I pre-rig the lines so the boat can only get a few feet off the ramp courtesy dock's end. When the stern of the boat rises during launching from the buoyant force, the forward portion wants to pitch downward. This is when the keel rollers under the forward half of the boat come into play. With these rollers preventing the bow portion of the boat from being pushed downward, and with the rollers taking the load, and with the rollers being very easy to rotate due to good lubrication, the boat will come off the trailer very easily--in fact I was very surprised at how easily; after I refurbished the keel rollers the boat just about flew off the trailer on the next launch. We had to revise our technique to account for the much improved rolling action of the new rollers. |
| sjp2 |
To get the boat off the trailer is no problem, but getting it back on the trailer seems a bit more stressful on the hull. This is my first fiberglass boat. I am still getting used to the tenderness that they require, but, in saying that, a fiberglass boat is a damn [sight] easier to fix than an aluminium boat and a lot quieter. [This thread has been edited to conform to our minimal style requirements regarding capitalization of the initial letter of the initial word of a sentence.--jimh] |
When loading the boat on the trailer, again I use the waterline marks on the guideposts as a guide to immersion. I typically immerse the trailer so those waterline marks are just below the surface. I never use the power-loading method, that is, using the outboard engine to propel the boat upward onto the trailer. Typically at the ramps I use that method is prohibited. The boat floats onto the trailer bunks about halfway, and is winched the rest of the way. If the boat seems like it is harder than normal to winch up, I will back the trailer in deeper, but usually only to the point where the guide marks are perhaps two inches below the surface. I can usually winch the boat into the winch stand rests with the winch on the fast speed setting. As Swist mentioned, the slope of the ramp will have an influence on the depth of immersion of the trailer wheels during launching and loading. |
