posted 01-17-2014 12:11 AM ET (US)
I have the 1991 version of that engine. In fact, I have 2.Come fall, I pull the fuel lines off while it is running, and when it begins to sputter, I choke it by spraying fogging oil into the carb intakes. Then maybe 3 minutes per engine to pull each plug and put a shot of fogging oil into each cylinder.
Total time to winterize 5 minutes. Not sure why you would bother to run it every weekend unless you just like playing with your boat in the driveway...
My engines have never failed to start come spring (usually on the first turn of the key).
