| Author | Topic: Now what to do with this trailer |
| ocean31 |
So....here it winter time and find myself with plenty of time on my hands, not much money and a old aluminum float on trailer. So I thought I would see if I can make this old trailer work with my classic 17 hull I picked up this trailer cheap, it had been so poorly used that someone bolted the axle directly to the frame instead of replacing the rusted away springs. SO...brought it home, installed proper springs and now am trying to figure out how to configure the supports for the hull. My question is.......do try to install some rollers? Put a 2 by 8 board down the center and do a rough cut and install on the side wood bunks? Or what? Maybe do a rough adjustement on the current wood that is installed on the cross beams, load the boat and see what happens? THe trailer is Aluminium slide on out of St Petersburg FL. It is one the early models with leaf springs instead of torsion springs. Here is a link to my photo bucket lib. http://s1206.photobucket.com/user/ocean31/library/?sort=3&page=1 Currently there is three large pieces of wood set on the only three cross beams/members and two very large side bunks. Does any else have this kind of trailer? If so how is your wood configured? Should I just junk the wood and see if I can install three rollers? Just three rollers seems to few. Thoughts? Thanks Ocean31 |
| conch |
Looks like plenty of trailer for a 17 hull. On my Slide-On the wood beams mount to the top of the trailer frame,the top of each bunk cut on a 45 at the top inside and carpeted and 1X6 set on either side of those V blocks also carpeted. Metal braces form a 45 from both the beams to the cross members. I would not put roller bunks on. Mine carries a 27 on triple axles. |
| Binkster |
http://s1206.photobucket.com/user/ocean31/library/?sort=3&page=1 |
| Tom W Clark |
The classic Whalers should be supported by keel rollers. It would be easy to adapt this trailer to such a system. Yes, unbolt the amateurish wooden blocks and throw them away. Likewise, remove the bunks and discard them. Add brackets and rollers to each cross beam (or double rollers if it makes you fell better) and then a pair of small carpeted bunks with adjustable brackets. All of that is simple off-the-shelf stuff that can be ordered form any number of vendors. The photos do not show the trailer in its entirety, but it appears another cross beam could be added at the ends of the main frame rails. I'd remove the winch stand and its support (which are painted steel) and have them hot-dipped. With new lights, wiring and fenders and the trailer will be better than new. |
| Peter |
I had an aluminum float-on type trailer under my last Outrage 18. It came stock with just the two cypress side bunks and a bow support. I added another set of bunks supported by adjustable brackets in the center to support the keel. This worked quite well. The float-on type trailers really make launch and retrieve easy. |
| conch |
From your pictures it is hard to tell if you have a trailer jack. Mine is a top crank style mounted at the front of the V made by the frame at the coupler. As original from Owen & Sons the Slide-On has no rollers. The keel area is fully supported by two center bunk boards from front to rear fastened to the V shaped wood supports on the cross members you still have. |
| zotcha |
Owens and Sons Aluminum Slide-On are THE trailer! Custom and cheaper than the cookie cutter name brands. AND a pleasure to deal with. Still all family operation. Oh, and I have two. zot. |
| DeeVee |
I have an Owen and Sons trailer under my Outrage 22. It was not set up very well for the boat when I acquired it. It was too high to be used on some ramps that I used- you couldn't get the boat off of the trailer. I lowered the trailer and lowered the boat on the trailer. I replaced the axles with new drop axles to lower the trailer frame. Then I added 3 C-channel cross members to the two that were original. I installed double keel rollers on the cross members. This lowered the boat so that the clearance between the sponson keels and fenders was a little over an inch. The bunks are mounted on top of the main frame rails. The connection between the frame rails and the wood bunk is staggered lag bolts from under the top flange of the rails. I can see the lag bolt holes on the top of your trailer rails. The tops of the bunks are ripped to match the hull dead rise. I replaced the bunks to match the new elevation of the hull, with the keel firmly bearing on the rollers. It is important to have the angle of this cut be correct. I was used to a roller trailer under my Sakonnet, so the learning curve was pretty steep with the larger boat and the bunk trailer. The launching turned into a piece of cake with the new setup. It took me a while to get the loading figured out. It turned out that it was better to have the trailer further out of the water while loading, as the keel would positively engage the aft keel roller, keeping it centered on the trailer while winching the boat to traveling position. I hope this helps, Doug Vazquez |
| ocean31 |
Wow, thank you everyone for the replies. It would seem that Ownens and Sons configures each trailer slightly different using the basic system of three large V shaped wood blocks in the center, then Two large/Tall wood bunk boards. THese boards may either be attached directly to the V blocks or to the side frame. In either case there is a support 45 degree bar going up to the side boards. This observation is based upon Conch's report and on internet pictures. My general preference is for adjustable keel rollers and adjustable 2x4 bunk boards. HOWEVER......Ownens and Sons seems to have a very large satisfied customer base. Again and again you find that people are very happy with their Owen and Sons trailers. It would seem that would I should do is configure the trailer just as Owens would have provided it for a classic 17. THEN...if I do not look the performance it would be a simple matter to remove all the wood, and install at least three keel rollers and two 2X4 bunks. Please remember, it is winter, and I have way to much time on my hands. As such......does anyone happen to have a classic 17 on a Owens and Sons Float On trailer? If so could you tell me what size blocks are used and how the bunk boards are configured? Other words....if you have a classic 17, the center of the V on the blocks is "XX" inches tall....the boards are attached to the V blocks or attached to side frame....? The side boards are "XX" inches tall. Anyway, you get the idea. I did call Owen and Sons, they were unable to tell me their wood sizes, they said each trailer is done for a specific boat. They do not keep on hand measurements for certain boats. Again, Thank you all for your replies. Ocean31 |
| conch |
Keep your upper wood beams on top of the frame rails, get them off the cross members.This is a great part of the strength of Slide-On,the 100% supported beams. The wood on mine is 4X12 on edge for 8.5K lbs. Try 4X6 for your beams, the lower bunks fasten to the wood V shapes,they do not touch each other at the keel,but are about six inches apart at the center and can be (2)1X6 or 2X6 planks. Start with the beams on the trailer frame then fit the wood to your hull. You can add carpet later. |
| ocean31 |
Thank Conch and DeVee. The idea that the side bunks ride on top of the trailer beams makes sense. As DeVee said, you can see the old holes for the lag bolts. One of the big concern I have is the over all height of the assembly. My current trailer is a over sized bass boat trailer with rollers. All the cross beams and rollers dip down lower then the trailer beams, (if I explained that properly) as such it does not take a lot of water to launch the boat, especially since it is a roller trailer. With the current steel trailer the bottom of the boat is about 14 inches off the ground. With this rig, I would think you really have to get the trailer deep into the water to float it off. With the float off trailer the keel of the whaler is going to end up somewhere around 24 inches off the ground. SO....now what, I think I will bolt a couple 4X4s on top of the trailer beams using the existing lag bolt holes. Trim the top of the V blocks down a inch or so, and then just go see what happens. I figure I can not do any real damage just pulling the boat out of the water. After I pull her out at the ramp, if I feel the system is way off, then just put the classic 17 back on the steel trailer. And of course I still have the option of adding another cross beam and just install rollers. Either way I go, should keep me busy for a couple days at least. Let you know how it looks, and will see if I can post a couple pictures in the photo bucket. Thanks Ocean31 |
| zotcha |
Did you speak to Jeff? He is very knowledgable with all hulls, specifically SeaCraft in my case. His sister Kim answers the phone and brother builds in the back. Anyhoo, I find that all Owens and Sons do ride higher than most on the street, you are correct. Here in the Carolina's, with an avg. 8 ft. tide swing every 6 hours, loading becomes difficult. However, while launching in Fla, with a less steep ramp, or smaller tide swing, I was over dunking the entire rig. These are true facts. In all, I believe that I have learned that roller trailers are not as recommended as bunks, except MAYBE for the keel support... Am I wrong? My 15's keels are supported. However, most weight is on the outer sponsons, resting on 45* carpeted bunks, pitched inward, to catch the arriving/departing hull. Keel rubs StarBoard type material while centering, until bow eye is secured to trailer... Anyone feel that this is wrong? Just askin. zot. I find myself more concerned with outboard position, trimmed up, and manually locked, steering wheel tied with ropes/bungee cords, to keep outboard from swinging back and forth. I have broken two Yamaha steering tubes, while mounted to a Bob's manual jack plate while minimal trailering back to dealer for routine service. 36 miles and over one set of rail road tracks. Yamaha ultimately decided not to replace (third tube), under warranty, should it happen again, which it has not. I really do like the quality of these trailers. |
