| Author | Topic: Clear Plastic Washers |
| Tom C |
I am refinishing the wood on a classic 15 SS. Several members have mentioned in the past of using a clear washer under the metal washer to keep the new finish from being "cut" when the screws are tightened. Where can these be bought? Any help will be appreciated. Tom |
| picflight |
I would think the big box stores might have them or perhaps these are what you are looking for: |
| Ridge Runner |
Here you go: http://www.jamestowndistributors.com/userportal/product.do?part=73926& SHOPPING&CA_6C15C=458289601 |
| RandyV |
McMaster Carr supply carries all sizes of Nylon washers. www.mcmaster.com I suggest getting black if possible, they are more UV resistant. |
| tedious |
Any decent hardware store that sells fasteners in bins will have a variety of nylon washers available. Tim |
| jflots |
Our local Ace hardware has bins of different sized ones. Not sure if they're clear or off white. |
Any good hardware store will have plenty of white nylon washers. Why not just use a flat stainless steel washer? |
