  Super-tauk 17 Thru-deck for Fuel Hose
Author Topic:   Super-tauk 17 Thru-deck for Fuel Hose
hullinthewater posted 02-25-2014 07:53 PM ET (US)   Profile for hullinthewater   Send Email to hullinthewater
In the process of converting my [1987] SUPER SPORT 17 to a Super-Tauk with a 12-gallon Moeller fuel tank on deck, under a lean post type seat, and it never had a thru-deck opening for the fuel line to the stern. I'll make a minimal 1.5-inch x 3-inch oval opening thru deck on [the center line of the rigging] tunnel, but instead of using a metal or plastic hawsepipe fitting, I'd like to slightly radius the deck edge of the oval cut out, and then fair it with a few layers of fiberglass cloth and West System, extending the fairing down and into the aluminum tunnel. I think it would look better and not create a water dam effect that would otherwise occur with a metal or plastic hawsepipe fitting. [Give your] opinions [and] comments.
DaveS posted 02-25-2014 08:59 PM ET (US)     Profile for DaveS  Send Email to DaveS
Just a thought: have you researched that topic yet? If memory serves me correctly, there have been several projects similar to what you are planning to do.
Good luck!
hullinthewater posted 02-25-2014 11:44 PM ET (US)     Profile for hullinthewater  Send Email to hullinthewater
By research, I'm guessing you mean doing a search here at CW? I've found threads discussing where and how to make the thru-deck opening, and the availability of the Boston Whaler part, which a form of does exist thru [a retailer], but I'm interested to see if others might have improved the basic idea.
FISHNFF posted 02-28-2014 02:06 AM ET (US)     Profile for FISHNFF  Send Email to FISHNFF
Check with Whaler if there is an existing tube glassed under the deck. On my 2000 17 Alert, converting it into a Montauk-Guardian was easy. The tunnel already existed and the installing dealer just needed to cut a hole into the deck at the forward end of the tunnel and glassed and gel-coated the edges. There was a smooth spot in the nonskid showing where to cut.
FISHNFF
contender posted 02-28-2014 08:15 AM ET (US)     Profile for contender  Send Email to contender
Use a length of PVC for the tunnel--it will not rot--and just fiberglass right over it. This gives you a tunnel and you have the ability to change out things. Also by using PVC you have numberous different type fittings for each end. Good luck
