  1988 Yamaha 90 Oil Leak
Author Topic:   1988 Yamaha 90 Oil Leak
jwestwood posted 05-17-2014 08:50 AM ET (US)   Profile for jwestwood   Send Email to jwestwood
From reservoir at the level sensor [on a 1988 Yamaha 90-HP engine] there is an engine oil leak. I am looking for repair suggestions. If you have had similar problems, I would appreciate your input. As always, thanks.
jimh posted 05-17-2014 11:29 AM ET (US)     Profile for jimh  Send Email to jimh
Typically those under-cowling oil reservoir tanks are plastic. If the leak is from a crack or split or fissure in the molded plastic tank, a repair might be possible with some sort of resin or adhesive or sealant, although often those tanks are made of a type of plastic that is not particularly easy to make a good bond with. If the leak occurs at a seal, perhaps a new gasket is in order. Also, sometimes the tank cap is a source of leaks.
jwestwood posted 05-19-2014 10:45 AM ET (US)     Profile for jwestwood  Send Email to jwestwood
Thanks Jim. I have also found advise suggesting two zip ties. I don't believe it is leaking at the cap as the oil level is below the cap. Will inspect sensor joint for fractured reservoir or bad gasket/O ring. It seems starter must be pulled to allow for sensor joint inspection.
