  Electrical Fuel Pump
Author Topic:   Electrical Fuel Pump
contender posted 05-22-2014 09:29 PM ET (US)   Profile for contender   Send Email to contender
Does/have anyone ever use an electrical fuel pump for their outboard?
jimh posted 05-23-2014 10:00 AM ET (US)     Profile for jimh  Send Email to jimh
I don't have and have not used an electric fuel pump in my boat--well, maybe I should qualify that because there is an electric fuel pump in my present outboard engine, a modern engine with a pressurized fuel rail, and I think you are talking about a fuel lift pump to raise fuel from the tank to the engine--but I see electric fuel pumps in use in small outboard racing boats.
sosmerc posted 05-23-2014 03:00 PM ET (US)     Profile for sosmerc  Send Email to sosmerc
What specifically is your application? I have used electric fuel pumps for some special applications, but the output pressure MUST be properly regulated.
contender posted 05-23-2014 03:40 PM ET (US)     Profile for contender  Send Email to contender
1st I just thinking I probably would never do it but always thinking...I run a 140 looper with no VRO, cost of a new pump is $380-450 depending on were you purchase them, Using a electric fuel pump (with a regulator set at 3 psi) this would be a lot cheaper and never have to pump/have a fuel bulb again. Also would make it easy to empty the fuel tank if needed.
sosmerc posted 05-24-2014 09:05 PM ET (US)     Profile for sosmerc  Send Email to sosmerc
I understand, years ago I rigged a 200 Evinrude Looper with a Holley fuel pump and regulator in the boat...Pushing fuel thru a Racor water separator assembly. We eliminated the VRO.
I believe we set it for 5 PSI. Never had fuel starvation issues or oiling issues again.
conch posted 05-26-2014 11:20 AM ET (US)     Profile for conch  Send Email to conch
Johnson and Evinrude both used an electric lift fuel pump with their Sea Drive models V4,V6,& V8.
Might be hard to find now. Online diagrams look like an auto style electric fuel pump.
contender posted 05-26-2014 05:19 PM ET (US)     Profile for contender  Send Email to contender
thanks
