  Console Door Catch
Author Topic:   Console Door Catch
cwkaiser posted 06-11-2014 02:05 PM ET (US)   Profile for cwkaiser   Send Email to cwkaiser
The little ball and spring latching unit [catch] that is attached to the console door frame on my 1987 Outrage 20 no longer grabs the latch bar of the lock securely enough to keep the door closed. Where can I find a replacement?
jimh posted 06-11-2014 02:36 PM ET (US)     Profile for jimh  Send Email to jimh
http:/ / www. jamestowndistributors. com/ userportal/ product. do?part=5 094& engine=adwords!6456& keyword=product_ad& gclid=CjkKEQjw_N-cBRD2k73X 3OjJ8eMBEiQAbdPic3CCVlhhwdSui-3u01YgwhlLZm0x2z32BM-knevkFuXw_wcB
and probably many other vendors.
jimh posted 06-11-2014 02:37 PM ET (US)     Profile for jimh  Send Email to jimh
http://www.google.com/search?client=safari&rls=en&q=Sea-Dog+Brass+Stud+ Catches&ie=UTF-8&oe=UTF-8
gpj posted 06-11-2014 09:29 PM ET (US)     Profile for gpj  Send Email to gpj
I have the same latches on my Montauk hatches. The prices in Jim's links are pretty low, by boating standards. If you prefer to rehab the existing latches, you may be able to replace just the internal springs.
The ends opposite the ball have a setscrew that can be removed with a flat blade screwdriver. Take out the screws and you can remove the ball and springs. My springs were completely corroded. I bought replacement springs at the hardware store for about $0.25 for each latch. I cleaned and lubed the balls, inserted the lubed replacement springs, and replaced the set screw. The latches are now as good as new.
I got the springs at my local Ace Hardware Store, which has a nice selection of hardware. Make sure the one you get is not too stiff. You can adjust the length by stretching a short spring, or cutting off a few coils for a spring that is too long. You may be able to increase the clamping strength by adjusting the depth of the set screws.
Sounds like a lot of work to save $10!
sail16 posted 06-12-2014 10:16 AM ET (US)     Profile for sail16  Send Email to sail16
I need to replace the missing latch(es) on my 1988 Montauk.
Can you tell me how many are used on the console hatch located directly below the helm?
ratherwhalering posted 06-13-2014 12:28 PM ET (US)     Profile for ratherwhalering  Send Email to ratherwhalering
One.
