posted 07-11-2014 10:02 AM ET (US)
I've been a longtime reader of ContinuousWave, but this is my first post.I need to purchase a new steering system for my 1987 15' Sport and I'm not sure what to get. The boat is used to get to and from an island off the coast of Southport, NC. Given the tides, the wind, and the current of the Cape Fear River it is often very tumultuous water, so I built a console for the boat that enables the captain to sit or stand depending on conditions.
I didn't want to have to worry about refinishing the console in future years so as much as I like the look of mahogany, I decided to build the console out of 3/4-inch-thick King Starboard. It came out great, but heavier than I anticipated. Therefore without any passengers aboard the weight of the console and the captain cause the boat to list heavily to starboard unless it is up on plane. To fix that I'm planning on relocated the console to make the boat a CC. I plan on cutting a section of the deck, installing a PVC pipe, then glassing the deck back together, similar to other projects that have been posted here.
Here is my delema: I don't know how long the steering cable needs to be because I'm not sure where the console should be placed fore/aft. I'd like to use some trial/error to figure out the best weight distribution of the battery, fuel tank, and console before cutting the trench. The current steering cable isn't long enough to use, so I need to purchase a new steering system, but I need some flexibility so that after I determine the correct console placement I will be able to re-route the steering through the not-yet-installed-below-deck-PVC-pipe.
It seems to me that hydraulic steering is better than cable steering for my purpose for two reasons:
(a) It feeling like having a cable rise out of the sump vertically and then loop around to the steering tube would look sloppy.
(b) I can leave the hoses longer than I ultimately need, then once I'm done playing around with console placement I can built the rigging tube and use appropriately long hoses.
The boat has a Bob's Machine hydraulic jack plate, so there are no issues regarding splash well width.
Since the boat has only a 50 hp 2-stroke Yamaha, and has a max rating of 70 hp, the Baystar system seems to be an appropriate choice, but based on posts I've seen I have 2 concerns with Baystar:
(1) Tubing flexibility - it sounds like the Seastar system would be easier to work with during the trial/error portion of my project.
(2) Number of turns lock-to-lock. I read somewhere that Baystar would be a 6 turns lock-to-lock setup which seems way to bus-like for a 15' Whaler. I'd rather be closer to 3 turns to make this boat more fun to drive.
So, I'd love to hear comments from others who have done center console conversions.
In summary: Should I go for a hydraulic system? If so, which one? Or, should I buy an Xtreme helm system with a cable that is my best guess for what length I'll ultimately need, and then just buy a second cable if it turns out I need something different.
Thanks for any advice,
TJ
