Topic: Why bother with foam? -- Rigging tube
TTB |
posted 07-28-2014 06:53 AM ET (US)
Hi all,On my 1987 15-Sport I'm performing the PVC rigging tube modification that has been described in various continuouswave threads over the years. I'm considering not refilling the void left under the deck with foam. I understand the structural advantages of the Boston Whaler manufacturing process that results in a foam core that is bonded to the skin on both sides, but I don't think that aerosol foam is going to provide the same structural benefits. It seems to me that once the original foam/deck seal is broken that the structural aspects of the foam are gone. I feel like spray foam is simply just going to make a mess without providing any real benefits. Here's what I thinking of doing: Prior to making the cuts which will allow me to temporarily remove a portion of the deck I was going to take a few scrap pieces of 1" square aluminum tubing about 16" long and screw them to the deck such that the scraps run across the area to be removed. I'll make sure that I screw each of the scraps (a) port of the rigging tunnel area, (b) on top of the rigging tunnel area, and (c) starboard of the rigging tunnel area. I'll then remove those scraps. I'll then cut out the portion of the deck, dig out the foam, and install the PVC. Then I'll reassemble the deck by using the same scraps of aluminum tubing screwed into the same screw holes. Then I can just use some fiberglass cloth to "repair" the seams. A few layers of fiberglass cloth on top of the seams are going provide orders of magnitude more structural integrity than the foam would. So what is the point of adding the foam? Thoughts? TJ
deepwater
posted 07-28-2014 03:27 PM ET (US)
The foam will fill in the voids all around and you can trim it back to where you pore in epoxy and lay as may layers of glass as you want |
TTB
posted 07-28-2014 05:18 PM ET (US)
But what is the advantage of filling the voids? I don't need the foam to place the deck back in its proper place because the aluminum tubing will do that. I'd rather NOT have the foam "contaminate" the edges of the deck when it expands. I'd prefer to use neat epoxy to wet all the edges, install the piece of the deck, then use a syringe to inject thickened epoxy into the crack. I suppose after I've done that I could let the epoxy cure and then inject aerosol foam, but I don't see the point. It makes more sense to me to lay up the glass before the thickened "crack filling" epoxy cures so that all the resin links together. I suppose I could do all the glass work and after curing I could enlarge the holes I used to temporarily attach the aluminum and inject foam. But that brings me back to the question why does it matter if the voids get filled or not? Thanks for helping me think through this. TJ |
deepwater
posted 07-28-2014 05:58 PM ET (US)
It will support the rigging tube along its whole length and there will be no room for water to pool,,I think once you trim shape and sand down the weak foam fill you will beable to back fill using a stronger epoxy and glass mat thicker than the factory deck but still attaching it to the sides of the deck along the cut,,I don't think you need the aluminum at all,,,,is the alum to be used to stop flex and twisting,Your not going to put a 200 HP motor back there are you |
TTB
posted 07-28-2014 06:51 PM ET (US)
No. Perhaps I wasn't clear. The aluminum is only temporary. I'll attach it to the deck to make screw holes. I'll then remove it and make the cut. When it's time to reinstall the section of deck I can reattach the aluminum tubing using the same screw holes. That will be used to hole the section in the proper place to do some glass work. Then the aluminum gets removed and I'll patch those little screw holes. TJ |
Binkster
posted 07-28-2014 06:57 PM ET (US)
What do you plan to do about the non skid pattern on the original floor and how do you plan to dig out the foam. The deck is built from 1/2" either 3 or 4 ply plyood. Its the same cheap stuff we used to sheet roofs on homes, its hardly the type of wood I would use to make a lid. The spray in foam does create rigidity and keeps out water and moisture. A couple of layers of glass cloth over the seams will cause a raised portion of the floor and will not be strong enough. Some people dug out the foam and built a through like box in the floor, glassed it in, and then put a removable top over the box. Alot more work and problems.rich
TTB
posted 07-28-2014 10:14 PM ET (US)
That's disappointing that the original deck is crap. I was thinking it would be wise to try and save it. It sounds like it would be better to not do so.My plan for the non skid will probably make the Whaler purists on here cringe. I was going to use a disk sander to remove all of the non skid on the flat portions of the deck. (Not on the sections that slope up to the bow.) I was then going to paint that portion of the deck with Awlgrip with some sand in it. This boat gets used for fishing / crabbing / goofing around in the marsh, and has been for nearly 30 years. She is no beauty queen, and cosmetics aren't very important to me. I've seen the 100% glassed in version of the rigging tunnel mod. It's probably stronger, but like you say it would be a lot more work. TJ |
TTB
posted 07-28-2014 10:23 PM ET (US)
Oh yeah. To remove the foam I was just gonna use a multi-tool and go nuts. Does it require more thought than that?TJ |
Binkster
posted 07-28-2014 10:52 PM ET (US)
The multi tool is what you need but first take a hand saw and cut through the foam to the underside of the bottom at the sides of your cutout. Then cut 3 or 4 parallel cuts and some crosscuts with the handsaw, then the multi tool will pop the pieces out like big ice cubes, and you will have a neat job. I think when you get the foam removed and the PVC tube installed, you will realize you need to foam that tube in. How do you plan to install the fuel line. Most Ive seen if the tank is under the RPS is the fuel line runs through the floor into the tunnel and out the rear of the tunnel into the sump.rich |
Binkster
posted 07-28-2014 11:06 PM ET (US)
As far as the purists and their factory non skid pattern, once you paint AwlGrip over it the factory nonskid becomes as slick as ice. What I did was spray the floor or you can roll it then immediately sprinkle the sand over it, don't use too much. Then when it dries hard roll another coat of AwlGrip over the floor. Don't mix the sand and the paint.rich |
TTB
posted 07-29-2014 08:00 AM ET (US)
I plan on putting the fuel tank in one of two places, I haven't decided yet.(1) I'd put in just fore of the console and build some sort of shelf on it to use it as a seat. (2) I'll put a cooler just fore of the console to use as a seat and I'll put the fuel tank on the deck in the back of the boat. I suppose I could put a tee in the rigging tunnel and have another "entry point" just under the seat. TJ PS - I'm glad you liked Whink. It really is amazing stuff. |
deepwater
posted 07-29-2014 06:01 PM ET (US)
How big O/D is the PVC |
TTB
posted 07-29-2014 06:19 PM ET (US)
I'm not sure (nor do I care) what the OD of the actual pipe is, but the OD of the end of the elbow that will come up under the console, and the OD of the coupler that will be epoxied to the sump are both 4" give or take a smidge. I figured I needed to buy a hole saw for the elbow end, and rather than buy a second hole saw for the sump I'll just put a coupler on the PVC so I can use the 4" hole saw at both ends. TJ |
deepwater
posted 07-31-2014 05:27 PM ET (US)
I was just trying to get an idea of just how wide and deep ou were cutting digging and filling,,,Good luck |
