  Bent Steering Rod...What to do...
Author Topic:   Bent Steering Rod...What to do...
NeverLand posted 08-12-2014 05:42 PM ET (US)   Profile for NeverLand   Send Email to NeverLand
I managed to bend the rear/upper steering rod at the motor mount on my 1987 OR18'. It's a small bend and prevents the boat from making tight turns to port. Turns to starboard are fine.
Question: Can the bent rod be repaired? If not, what's involved with replacing the rod and/or cable? Is this an easy DIY?
Many thanks,
Ian
Peter posted 08-12-2014 05:52 PM ET (US)     Profile for Peter  Send Email to Peter
I would replace cable. Not sure on an Outrage (always had hydraulic steering on mine) but some other boats require that the motor be taken off the transom to replace the mechanical steering cable because the boat structure blocks the cable from traveling through the tilt tube.
