posted 08-15-2014 02:49 PM ET (US)
Lenco tabs are overkill for a 15 ft. Whaler. Smart Tabs can work well if employed carefully. I have a 16SL, notorious for a slight stern heaviness and tendency to porpoise. I have an E-TEC 90 mounted all the way up and through experimentation have found two options to address the issue. The first is a 4-blade Rogue prop, 15" pitch. The second is a Stiletto Advantage II, also 15" pitch, combined with Smart Tabs, 40 springs set at their least resistance setting.
The Rogue is a "stern lifting" prop, and performs as advertised, jumping up on plane and eliminating any porpoising, but it's a bit too effective, as even with the engine all the way trimmed out I can't get the bow up to its most efficient level. The Stiletto/Smart Tabs combination also jumps on plane (perhaps even quicker, as the Stiletto is ventilated), with a more acceptable range of bow angle to engine trim. Emotionally I didn't want the Smart Tabs to work better, as I'd like to not have something hanging off my hull, but intellectually I can't deny their effectiveness. I do a lot of tubing and skiing with my boat, and the Stiletto/Tabs combination is just about perfect. Plus the Stiletto gives a couple mph extra at WOT, which helps with the emotional reconciliation!
I know my hull is different and heavier, and I have a two-stroke, which has a better torque curve, but I think Smart Tabs are just what you need, assuming you can get the installation to work with your swim ladder. I know you've also posted over at Whaler Central. If you check my personal page over there you can see how I dealt with the installation.
John K.
