  Montauk Bow Chock and Navigation Lamp: Stripped Fasteners
Author Topic:   Montauk Bow Chock and Navigation Lamp: Stripped Fasteners
wally910 posted 08-14-2014 04:36 PM ET (US)   Profile for wally910   Send Email to wally910
I removed the original bow chock and navigation lamp assembly from my 1986 Montauk in order to have it re-plated, and I have run into a snag. Like an idiot, I did not soak with penetrating oil the two fasteners that hold down the lens assembly prior to attempting to remove them, and as a result, partially stripped them. I have now been soaking them with PB Blaster and hope to have enough grab to remove them. Does anyone have a part number for a suitable replacement for these fasteners? Also, assuming I cannot get them out with a screw driver, what is the preferred method to remove? Thanks.
EJO posted 08-15-2014 09:25 AM ET (US)     Profile for EJO  Send Email to EJO
I don't know the fasteners but as with any stuck screw use an extractor or if you don't want to buy a special screw extractor (kit) still drill a hole and use one of your square tip driver bits. These square tip driver bits are slightly tapered so drill your hole in the screw equal to the smallest diagonal size of your square bit tip.
Push the tip in with a slight tap and lefty-loosie.
cohasett73 posted 08-16-2014 09:52 AM ET (US)     Profile for cohasett73  Send Email to cohasett73
Wally--from my 45-years of experience in tool and die, take the assembly to a machine shop. They will remove the screw heads to gain better access to the frozen screws. The rest is pretty much what EJO said. Were you closer, I would fix it while you watched--Tom from Rubicon, WI.
wally910 posted 08-25-2014 01:02 PM ET (US)     Profile for wally910  Send Email to wally910
Thanks for the replies. I have decided to take it to a machine shop and have them remove the screws.
hc803 posted 08-27-2014 12:26 PM ET (US)     Profile for hc803  Send Email to hc803
I ran into the same problem with my '87 and had to slowly turn via small vice grip pliers. My local Ace hardware actually had screws that fit (unsure of size, I just took one in, they were stainless). Didn't have the exact same look as the originals, but the pan heads sat even with the lens cover and the overall fit was tight.
cohasett73 posted 08-29-2014 08:38 PM ET (US)     Profile for cohasett73  Send Email to cohasett73
Wally,
Let us know how the stuck screw problem got resolved. remember, these fix it's are here for all posterior ;-)
wally910 posted 09-30-2014 11:13 AM ET (US)     Profile for wally910  Send Email to wally910
I ended up taking it to a machine shop and having them removed. Cost was $20 bucks and well worth it. I have the light assembly at a plating shop and when it is returned, I will find some suitable screws and post a description.
cohasett73 posted 10-04-2014 10:57 AM ET (US)     Profile for cohasett73  Send Email to cohasett73
Thanks for the up date Wally, I knew the machine shop would fix you up. Broken, stuck, sheared off screws are are our bread and butter jobs.
Tom from Rubicon
gpj posted 10-09-2014 02:26 PM ET (US)     Profile for gpj  Send Email to gpj
Wally - How much is the plating running you? Is the shop toing the prep work as well? Thanks!
andygere posted 10-10-2014 05:24 PM ET (US)     Profile for andygere  Send Email to andygere
Use some thread anti-seize compound on the new fasteners, and they will spin right out the next time. I use it on just about everything these days.
