posted 09-21-2014 01:45 PM ET (US)
If you have concern that the automatic oil-gasoline mixing is not working correctly in the fuel system of your two-cycle outboard engine, it is prudent to use a fuel consisting of some gasoline and two-cycle oil pre-mixed at about 50:1 ratio. Use the pre-mixed fuel until you are satisfied the automatic oil-gasoline mixing pump in the engine is working properly.If you properly prepared the engine for long term storage, it should be ready to come back to service without too much difficulty. If you have any doubts, it might be prudent to remove the spark plugs, insert a small amount of two-cycle oil directly into the cylinder via the spark plug hole, and then rotate the flywheel by hand for several rotations to verify the engine is able to turn over easily and nothing is stuck.
The simplest way to verify the automatic oil-gasoline mixing pump is working correctly is by running several gallons of fuel through the engine, and carefully observing the level of the oil reservoir tank. The oil reservoir tank level should go down by an amount appropriate to the volume of gasoline consumed and the anticipated mixing ratio.
