| Author | Topic: Compounding and Waxing |
| cvyarb |
I need to compound and wax the outside hull of a 27-footer. This boat was shrink wrapped and there is no oxidization to deal with. I have done this before when I was younger, but don't remember any of the specifics. I have waxed other boats but never compounded them. I would appreciate it if anyone could tell me how to do this or point me towards an article. My biggest concern is how hard to push and how much to compound the hull. I have no idea how much I need to roughen it up prior to waxing it. I appreciate your help. |
| andygere |
If the gelcoat is not oxidized, why are you compounding it? Just clean it and wax it. If it has some stubborn dirt or is not quite as glossy as you would like, an intermediate product like 3M Finesse-it polish prior to waxing may be the solution. The gelcoat is already porous, it will take wax without a compound job first. |
| cvyarb |
I assumed that it needed it since the boat has sat in storage for five years under shrink wrap without any compounding or waxing. My understanding of the purpose of compounding is that it helps prepare for waxing, in that it brings out the clear quality, shine, and depth of the gel coat. I am still trying to wrap my head around being the one in charge (temporarily) of restoring this boat, as opposed to being the second mate who takes direction. |
| cvyarb |
[Will there be any] input re the compounding advice specific to a Whaler? Thank you for your help. |
| whalerdude |
Start with 3M IMPERIAL GLAZE, then use 3M FINESSE-IT. After that use a good wax. If the oxidation is extremely heavy you may need to wet sand. 3M has a few excellent youTube tutorials that really helped me. I used a PORTER CABLE random orbit polisher with Velcro foam pads. I bought the polisher and pads from Griot's garage. Griot's garage has excellent polish removal cloths. I use all of their stuff for detailing my cars. I have a lot of fun polishing my Boston Whaler boat. My friends think I am crazy when they see how shiny my boat is. It's like "don't you fish with your boat?" |
| cvyarb |
Whalerdude, Thank you. That helps provide the steps I need to take to get this done. I really appreciate the input. |
I don't think there is anything about the gel coat of a Boston Whaler boat that will require special products or special methods to be used to restore the gel coat to a high luster. The Boston Whaler boat has a gel coat finish, and I have never heard of any characteristic of its gel coat finish that would set it apart from other boat hulls. Many report getting good results using COLLINITE FLEET WAX, a heavy and old-fashioned paste wax. My advice--which is certainly very non-expert advice--is to start with hand application of any polish or compound, as a test. Work by hand in a small area, and see if the product gives good results. For example, if you think the gel coat surface is already in sufficiently good shape that its shine can be restored with a very mild abrasive like 3M FINESSE-IT, try that product in a small area and see what result you obtain. If you get a beautiful high-gloss result with such a very fine abrasive, then you can plan on using that for the entire boat. If you don't see much improvement, you may need to use something more abrasive as the first pass. As I recall, it has even been suggested that four steps might be necessary: --oxidation remover Exactly what you will need to restore the gel coat on your boat will depend on the state of the finish it has now. The goal is generally to get the gel coat into a high-gloss or high-luster finish, and then apply a wax. Once you have the boat nicely polished and waxed, most dirt should be able to be cleaned off with just a light rinsing or with very mild soap. I keep trying to get to that state, but have not achieved it. |
| cvyarb |
JimH, Thank you for the information. I just wasn't sure whether there were any BW specific concerns, and you've answered that for me. It seems like I have a blueprint for how to move forward--do a test run on a small part of the hull. I appreciate everyone chiming in; everything I have been told here has really helped me move this project along with great results. |
| endus |
For the 3m products - (sorry I am a detailing guy and can't help myself :) ) Imperial Glaze is an oil based filler. On cars, it is mostly used to disguise swirl marks (rather than actually polishing them out). Finesse-it is an actual polish...i.e. an abrasive designed to remove marks and level out scratches. The correct order would be finesse-it, imperial glaze, and then wax. Basically, "polish out scratches, disguise the ones you don't remove, and then protect the surface". If you're polishing after you glaze, you're removing the oil which is what the glaze is really all about. Most automotive polishes also contain oil/fillers, so you're probably not noticing a huge difference, but glazing then polishing is just adding an extra step. Do the reverse or stick with just polish and wax to save a step. For auto, I personally use polishes that don't contain oil so I can see the actual condition of the paint as I work. I polish out the swirls and then protect, rather than using glaze to cover them. If you're careful with how you treat the car in terms of washing, there's not really a good reason to use glaze, but if the vehicle is treated more roughly, then it can definitely save a lot of work (and clearcoat) not having to polish it over and over again. For marine, just like a car, it would depend on how far you want to take it in terms of surface quality, though I doubt you're going to see defects in gelcoat as easily as you do in auto clearcoat. The porter cable 7424 is a great tool for both auto and boat. You can't burn the paint on a car with a random orbital like you can with a rotary polisher. The tradeoff is that it takes a lot longer to take any scratches out. For gelcoat, if I were using a porter cable, I would use a heavier abrasive and a wool pad. For auto paint you want to stick with a foam pad, but a heavier polish still isn't a bad idea to speed up the process. I have been doing this for a long time, so I use a rotary (Makita 9227c) on both car and boat. It lets you get better results in much less time, but you have to be careful with it. Burning right through your expensive paint job is not very difficult. When I went to start cleaning up my boat I used a foam pad on my rotary with some medium duty 3m polish, but it was taking too long so I went with a wool pad with the same polish and that worked very well. Were I to want to get a really great finish on the boat I'd follow up with a foam pad and a lighter polish, but I'm not interested in putting in that much effort on the boat: I already spend enough time detailing the cars! |
| endus |
Collinite is great hard-wearing wax and its what I will be using on my boat. It has a reputation of lasting as long as a polymer sealant will (~6-8 months) in auto applications. The more coats you put on, the longer it will last. I actually use collinite to wax the wheels on my cars because that's not something I want to deal with more than once per season. I haven't done the research yet to see if polymer sealants are popular for gelcoat yet. If they are, they're worth a look. They last forever, they don't stain trim, and they're not hard to work with. I actually discovered last weekend that Klasse All-in-One and Sealant Glaze work great for protecting the black plastic parts of my FJ Cruiser as well as the paint. Jim's right too about using the correct abrasive for the condition of the paint. Forgot to mention that. If you're boat is in amazing shape already a porter cable with a foam pad and a lighter polish is all youll need. If its not in as good a shape, then you might want to think about being more aggressive. |
| cvyarb |
Endus, thank you for chiming in. I will take as much info as I can get--very clear explanation and gives me a good road map! |
| PeteB88 |
Endus - what about 3M Super Duty? I have one boat that is oxidized that I don't use often. My main boat interior, console (vertical surfaces) are near perfect. The previous owner was meticulous, I'm not so perfect. I took my boat to a local pro-autobody supply outfit FinishMaster and to reputable big boat marine Barrett's Spring Lake MI and asked for recommendations. Both recommended Super Duty although made it clear my boat was not in bad shape but their techs would go easy with Super Duty to get the job done. Also strong recommendation to use hand application method as well. I have same Makita variable speed unit. Your thoughts? I really appreciate your comments. |
| endus |
Pete - No problem! With polish, it's mostly about time and effort. Not always, but usually, you can achieve the same results with a light polish as you can with a heavy one...it will just take more time and effort. For a surface that needs a lot of work the "by the book" method is to use a heavier polish, then step down to a lighter one to achieve the best shine possible. I really don't work with 3m products very much because they contain so many fillers, so it's tricky to say what kind of results you'll get with it (also not knowing your boat and experience level). If the yards suggested Super Duty, then that's probably a good recommendation. Depending on how picky you are, you may want to follow up with a lighter polish, but it doesn't sound like you're overly picky. Honestly, as picky as I am about cars, I wouldn't follow up with a lighter polish either unless it was really obvious that I needed to. Detailing is cumulative...hit it with the heavy polish this year and maybe go lighter next year when it's in better shape. I'm a big fan of this type of approach. If the yards were stressing hand application, that also plays in to their polish recommendation - i.e. they're recommending a heavier polish because hand application is less aggressive and takes more time and effort. If you do it by hand I would just get some basic hand pads from autozone or west marine and go at it. Keep applying until you've removed the oxidation you're looking to get out. If you go with the machine, I would use a foam pad and relatively low speeds. A rotary with a foam pad set on its minimum speed is still going to be more aggressive than hand polishing. Just make sure you keep the machine moving steadily all the time, don't sit on bumps or edges, and start out on flat easy panels until you get good at controlling the machine. I would do the machine myself. Hand pads are cheap, though, so buy a couple and see if hand polishing it seems reasonable. If it's too much effort step up to the machine and don't be too aggressive. Just another general side note - I learned the hard way (by burning my paint) when I first got my rotary that the "default" speed should be the minimum speed of the buffer. Always start out at that speed, use it when you're anywhere near an edge or a bump, etc. When in doubt, use the minimum speed. If you regard higher speeds as a "tool" to get the work done faster on panels where its safe to do so, that will usually keep you out of trouble. Keep the machine moving all the time. Minimum speed usually won't cause too much trouble if you stop moving, but at high speed the buffer will burn through paint in (literally) a second if you stop. Using high speed you need to make sure you're in a comfortable and stable position so you can control the buffer and keep it moving. If you're in an awkward position bending or reaching, don't use high speed. Gelcoat is a little tougher than clearcoat, but treating it like a car will keep you out of trouble until you get a better feel for it. |
| EJO |
The OP (cvyarb) said no oxidation so why are we mentioning oxidation removal. A BW is a fiberglass type boat with a gelcoat finish therefore if there is no oxidation you don't need to compound just wash and wax (by hand). I would use products made for boat finishes not just automotive finishes and I swear by Aurora Marine. Look at their stuff on www.auroramarine.com/fiberglass.php 27ft is a big boat and AM makes stuff to do it quick and make it look like new. Been there done that whith fantastic results. |
| PeteB88 |
Thanks EJO, I really appreciate it - Have all the stuff, been putting things off due mostly to crazy schedule and time. You broke it down just right. |
| PeteB88 |
Meant to include Endus big time, can't pull back my posts so best to all you guys!! and Thanks! |
| cvyarb |
Thanks to all--great information that will help big time. |
