posted 10-18-2014 12:02 AM ET (US)
The sun has just been brutal out here on the West Coast, and I was in need of some shade. I went with a lightweight T-Top, and it had to fit inside my garage. Now I have used it twice in running 20-miles offshore from San Diego. It has been very nice to have the shade.I put a T-Top [made by RNR Marine and called the MONTAUK SHADOW] on my 2006 Boston Whaler 170 Montauk. The T-Top construction seems good. It is stainless steel and Sunbrella canvas. The T-Top comes with stainless steel split-jaw clamps.
The [MONTAUK SHADOW T-Top by RNR Marine] attaches to the console and to the rear legs of the seat. I am able to move the seat back and forth and it does not affect the top. The seat in the back position is the most stable. There was some side to side sway on the rear legs, but I replaced the quick release pins with some wing nuts and washers and it reduced the sway considerably.
If you want [a T-Top for a Boston Whaler 170 MONTAUK that is] lightweight and can fold very low then [the MONTAUK SHADOW T-Top by RNR Marine] is it. If you want something very solid and bolted to the floor, go with something else.
ADVANTAGES:
--light weight, about 22 lbs
--lots of shade
--no holes to drill
--folds below windshield height
--can use front rod holders
--can add rod holders
DISADVANTAGES
--some side to side movement on rear legs
--back legs get can get in the way of fishing
--does make the boat feel a little smaller when moving around with rods and such
---when fully lowered, the canvas hits the rod holders on the front of the console and puts tension on the canvas and I'm afraid it might stretch out the canvas.
Overall I am quite happy with [the MONTAUK SHADOW T-Top from RNR Marine]. I have never been so comfortable running all day in the hot sun. It has definite worth for me.
I added a couple of rod holders and will probably add a few more. My radio antenna is not in the best position, and I need to remove ii when lowering the top to go in the garage.
Next up is building a vinyl windshield for the ride home.
