  Removing Color Lens From Combined Sidelight on MONTAUK
Author Topic:   Removing Color Lens From Combined Sidelight on MONTAUK
sail16 posted 10-18-2014 11:02 PM ET (US)   Profile for sail16   Send Email to sail16
I am about the send the [combined sidelight lamp] and bow fitting from my 1988 Montauk off for re-chroming. I would like to remove the original color lens from the lamp but it appears quite well attached to the lamp. Any advice on how to safely remove this irreplaceable part?
Jeff posted 10-19-2014 10:58 AM ET (US)     Profile for Jeff  Send Email to Jeff
Those lenses are not irreplaceable .They are very common parts and can easily be sourced. Those lens should be lose and POP right out. Sounds like they might be corroded in place? Do what you can to save them be if they get broken no worry about it.
I have bought replacements from A&A marine in Manistee Michigan.
http://www.classicboating.com/parts/bow-lights-and-lenses/ lense-bow-light-half-round
Specaility Marine also has them.
Jeff posted 10-20-2014 02:49 PM ET (US)     Profile for Jeff  Send Email to Jeff
Also, Marine Part Depot has them and they are only $7. I have bought hardware and now lights from them before and have always been happy with their products and customer service.
http://m.marinepartdepot.com/rebowlilefor.html
sail16 posted 10-20-2014 06:55 PM ET (US)     Profile for sail16  Send Email to sail16
Jeff,
Thanks. My combined sidelight lens does not look like the ones you reference. In particular, the top of the lens dome is cut out, leaving an open ring space, the perimeter of which appears to be glued to the top chrome fixture.
It appears to be factory original in that state (or very well refabricated after-the-fact).
Have you or anyone else see a lens like that?
Jeff posted 10-20-2014 10:59 PM ET (US)     Profile for Jeff  Send Email to Jeff
Do you have any photos you could share?
Jeff posted 10-21-2014 09:17 AM ET (US)     Profile for Jeff  Send Email to Jeff
Here is a pic of one of my old ones disassembled.
http://smg.photobucket.com/user/jeff_rohlfing/media/ebay/DSC_1687.jpg. html?sort=2&o=41
sail16 posted 10-29-2014 07:22 PM ET (US)     Profile for sail16  Send Email to sail16
Here's the fixture and lens.
http://i1272.photobucket.com/albums/y392/nbix/ 583C7ED3-293B-4D49-8531-D64B40D9E947_zpswki7sw5v.jpg
jimh posted 10-30-2014 09:53 AM ET (US)     Profile for jimh  Send Email to jimh
In the image (linked above) is the light brown material near the bottom of lens (in the image view) some sort of adhesive?
hc803 posted 10-30-2014 10:51 AM ET (US)     Profile for hc803  Send Email to hc803
sail,
this is what you want, or at least what i got for my 87:
http://www.amazon.com/dp/B005FCI4XS/ref=pe_385040_30332190_TE_3p_dp_1
hc803 posted 10-30-2014 10:52 AM ET (US)     Profile for hc803  Send Email to hc803
follow up:
mine was cracked and i had to use a flathead and a dremel to remove it. it's glued in.
sail16 posted 10-30-2014 02:38 PM ET (US)     Profile for sail16  Send Email to sail16
HC803: yes-- that's the lens! Many thanks. For those who are searching in the future, it appears to be Perko p/n 0296DP0LNS.
JimH: I presume that the substance you refer to is adhesive. The original question still stands-- how best to remove the lens? I would tend to start by trying some heat, then a solvent, and if those fail, physical force.
Has anyone successfully removed this style lens intact?
Binkster posted 10-31-2014 11:09 AM ET (US)     Profile for Binkster  Send Email to Binkster
Why bother, just remove that old lens and buy this one.
http://www.marinepartdepot.com/rebowlilefor.html?ref=lexity&_vs=google& _vm=productsearch
rich
Binkster posted 10-31-2014 11:22 AM ET (US)     Profile for Binkster  Send Email to Binkster
I was going to get my bow light replated, and it was proving to be expensive and complicated, so I chucked the whole thing and went this route. I am more than happy with the result. BTW the old lense just fell right out and is in very good shape.
http://www.marinepartdepot.com/newstoldstbo.html?ref=lexity&_vs=google& _vm=productsearch
rich
jimh posted 11-04-2014 09:00 AM ET (US)     Profile for jimh  Send Email to jimh
SAIL16--re your method for loosening a part held by an adhesive: I agree that some heat and use of a solvent is the best approach to loosen an adhesive.
