| Author | Topic: Degreasers For Use on Gel Coat, Aluminum, and Electrical Wiring |
| Frank O |
Is there a good degreaser I can spray into the bilge with a spray gun of some type that is safe for gel coat, the aluminum fuel tank, the bilge pump wiring, and etc.? I see Simple Green is not recommended for aluminum. |
| Jeff |
I have found Krud-Kutter to work as well if not better than Simple Green and it is non-toxic and safe on metals and gel coat. It will strip any wax off that you have in the gel coat, but so will simple green and other degreasers. |
I did not know that Simple Green was not for use on aluminum. I have been using it to get grease and oily stains off my outboard engine. I will have to try the product Jeff recommends. Can you find KRUD-KUTTER in most stores? I never heard of it. |
| Jeff |
Jim, The company was recently bought by Rustoluem and can be found all over now. I have always bought it at ACE, Home Depot, Lowes ETC..... |
| TahoeMontauk |
www.oileater.com/household/cleaner-degreaser This stuff is the bomb. Non-toxic, non-corrosive, biodegradable. |
| fishgutz |
I've heard this works really good: http://www.westmarine.com/buy/orpine--orpine-boat-soap-quart--3119930 I have used this quite a bit with excellent results: http://www.supercleanbrands.com/products |
| Frank O |
Thanks for the suggestions. I ordered some Krud-Kutter and will give it a try. Below is the FAQ answer on Simple Green's website about using the product on aluminum. Apparently the problems occur when it stays in contact with the metal too long. When used with caution and according to the instructions, Simple Green All-Purpose Cleaner has been safely and successfully used to clean aluminum. Simple Green All-Purpose Cleaner, Crystal Simple Green Industrial Cleaner & Degreaser, and Simple Green Pressure Washer Concentrates have been used on aircraft, automotive, industrial and consumer aluminum items for over 20 years. However, caution and common sense must be used: aluminum is a soft metal that easily corrodes with unprotected exposure to water. The aqueous-base and alkalinity of Simple Green All-Purpose Cleaner can accelerate the corrosion process. Therefore, contact times for unprotected or unpainted aluminum surfaces should be kept as brief as the job will allow - never for more than 10 minutes. Large cleaning jobs should be conducted in smaller-area stages to achieve lower contact time. Rinsing after cleaning should always be extremely thorough - paying special attention to flush out cracks and crevices to remove all Simple Green product residues. Unfinished, uncoated or unpainted aluminum cleaned with Simple Green products should receive some sort of protectant after cleaning to prevent oxidation. |
There won't be any problem for me to use SIMPLE GREEN. I tend to use it diluted from the recommend concentration, and I use it on painted aluminum surfaces. |
| DeeVee |
I second the recommendation for the Oil Eater. I have been using it for a long time. I am on my second gallon of it, purchased from Costco. It must take me 5-10 years to use a gallon. I used it to clean up my old 200 HP Suzuki, before I prepped it for painting. There is a lot of grease and oil to clean off of an old 2 stroke. I also use it for cleaning oil and grease drips and spills off of my shop floor. I try to keep spills and drips to a minimum, but when it does happen, the Oil Eater cleans it up nicely. As I write this, I remember that I need to get another gallon. Doug Vazquez |
Doug--I think you are the first to mention OIL EATER. Previously it was just called "this." |
| TahoeMontauk |
I called it "This stuff." The URL I posted clearly states the name of the product. |
Tahoe--Thanks for the follow-up and your continued recommendation of "this stuff." Calling the product "this stuff" will be very helpful when people search for information about "this stuff." |
| White Bear |
Greased Lightning |
| PeteB88 |
I've used Simple Green, Krud Kutter, per Jeff's recommendation, other stuff and Amazing Roll Off. I think Krud might have the nod but Roll Off worked great too. Good product but spendy. I don't want to spend $20/gallon on cleaners. |
