Topic: Recommend Cleaner for Stainless Steel, Aluminum
chiefrocka |
posted 04-19-2015 03:46 PM ET (US)
[W]hat products or applications do you fellas use to get the stainless rails back to original luster [and] shine?
deepwater
posted 04-19-2015 08:47 PM ET (US)
Mother's past [paste?] cleaner always did a good job for me. |
chiefrocka
posted 04-19-2015 09:55 PM ET (US)
Thanks. [O]n the OUTRAGE I just bought the T-top has an aluminum frame. [T]here [are] some areas of pitting on the aluminum. Can those be rubbed out? |
cleep1700
posted 04-19-2015 11:17 PM ET (US)
Spent last week polishing mine with Wenol, a polishing compound made in Germany that I bought from Amazon. Good stuff--Craig |
posted 04-21-2015 04:37 PM ET (US)
Defects in a surface finish can only be rubbed out if you rub away enough material to remove them. If the defect is a deep pit, a lot of rubbing is going to be needed. |
chiefrocka
posted 04-21-2015 10:09 PM ET (US)
[T]hanks. [S]ounds like I may need the right tool for the job to rub out some pits, or find a detailer to hire it done. [T]hanks--matt |
