| Author | Topic: Using a toggler anchor under deck 18 Outrage |
| FISHNFF |
I am still putting together my theft recovered 1988 18 Outrage. My aftermarket Todd Cooler seat with rod holders was tskrn, so I'm replacing my non-OEM seat with another non-OEM seat, this time a Wise SS framed swingback seat. The stem seat had 8 mounting screws through a flat poly base. A bunch of 5200. Solid. The new seat uses 1" SS pipe as a frame. Round stsinless on a whaler deck didn't seem like a good idea. Problem. There are only 2 screws on each leg. Each leg is 16" in length, holes 12" apart. So that's 4 screws holding down the chair. Has anyone successfully used SS toggler bolts to securely throughbolt to the deck of an 18 Outrage?
| dfmcintyre |
Are the legs situated so they will sit on the fuel tank cover? If so, I'd consider removing the cover and place an aluminum backing plate underneath.
| FISHNFF |
Removing the tank cover is not really an option. I'm just concerned if 4 #10 wood screws fastened into the deck of my 1988 18 Outrage is adequate. |
| Binkster |
Is this the seat you are considering? ($500) http://www.overtons.com/modperl/product/details.cgi?i=94564 if so, its not worthy of a Whaler and too expensive. The design is not bad, so print a pic. and take that and your cooler to a local T-top fabricator. Ask him to copy it using 2" polished aluminum pipe and weld 2 angles on each leg with two holes in each angle for screwing into the deck. Then take to to a marine apolstry shop, they can provide a seat and backrest. It might cost a couple of hundred more, but it will look good and not detract from your Whaler. rich |
| conch |
If that is the seat you will use then S/S U-Bolts can be used mechanically fastened to counter sunk holes in the starboard which is then fastened to the deck as before. 1" Tube O.D. S/S U-Bolt Cushion Pipe Clamp Item #: T9FB364874 Sold By: globalindustrial.co Chuck |
| Plotman |
No, you don't want to use toggle bolts on a whaler. |
| FISHNFF |
Seat already purchased. Not sure I'm gonna install. I had this before it was stolen. Copy on the toggles bolts. Will keep you informed. Sorry not traditional or OEM. FISHNFF |
| dfmcintyre |
Since removing the fuel tank cover and using a backing is not an option, I thought I'd try and describe another method that's been used in the past, if needing to attached hardware to a deck with no wood backing. It comes from the West Epoxy people: Drill the hole through the composite, larger than needed. Use a nail bent 90 degrees, and attached to a portable drill. Feed the nail through the hole and turn on the drill at low speed. Shop vac out the debris. What your trying to achieve is a large (though not very deep) void in the foam, under the laminate to spread the out the anchor point. Regards - Don PS - If you search in the West Epoxy website, I believe there's an article in their archives. |
| dfmcintyre |
Sorry - didn't finish before hitting the send key. Pour slow setting epoxy into the void, flush to the deck surface. When cured, you have a larger epoxy plug to attach to. I used a modification of this method. After using the method described earlier, I poured in the epoxy and placed a stainless steel barrel bolt ( http://www.grainger.com/product/GRAINGER-APPROVED-Barrel-Bolt-WP73990/_/ N-/Ntt-barrel+bolts?nls=1&sst=subset&s_pp=false&picUrl=//static. grainger.com/rp/s/is/image/Grainger/5LY84_AS01?$smthumb$ )into the liquid and let the epoxy set, with about 1/4" of the barrel exposed. Regards -Don |
| Mike Kub |
Twin pedestal seats were common on that boat from the factory and they were just screwed in. . Unless the wood underneath is rotten nothing else is needed. When you get into working on that boat the quality of manufacture is amazing. Peace |
