Topic: 1991 SUPER SPORT 13 Restoration: Replacing Wood with 3M4200 Adhesive
huntpayne |
posted 05-18-2015 10:12 AM ET (US)
I removed, repaired, and refinished all wood from a [1991 Boston Whaler SUPER SPORT 13]. The wood had been previously bedded with some sort of compound, adhesive, sealant, or something. Is replacing the wood with some sealant such as 3M4200 (or other) a good thing? If so, what should I use? Thanks.
Powergroove803
posted 05-20-2015 08:54 AM ET (US)
I am currently refinishing my wood on my 1977 Outrage. I did not bed it down, and I am glad I did not, as that would have made it even harder to remove. I would seal the screws with silicone and not bed. |
posted 05-20-2015 09:18 AM ET (US)
I would only consider sealing any wood that directly mounts to the deck and then only if it was plywood.Butch |
EJO
posted 05-21-2015 03:57 PM ET (US)
In my Chris-Craft restorations I always used the Sika brand (Sikaflex tubes), Dolphinite, or Interlux Boatyard in a can. Personally I stay away from 3M unless you need to glue something; then the 5200 and 4200 are great. But for bedding an item to a boat use the [Sika brand (Sikaflex tubes), Dolphinite, or Interlux Boatyard in a can]. |
posted 05-21-2015 09:38 PM ET (US)
Why are you replacing wood with sealant? I don't understand how you have used the word "replacing." Can you clarify? |
