Topic: 1996 Outrage 19 Scupper is Loose
97dauntless17 |
posted 05-22-2015 11:23 AM ET (US)
The starboard side scupper on my 1996 Outrage 19 is loose. Is there a way to remove it, or tighten it? I think I need to remove it and check for water intrusion and then seal it properly. Thanks.
Jeff
posted 05-22-2015 01:45 PM ET (US)
Scuppers are usually installed using screws from the exterior. Are you referring to a Thru-Hull fitting? One with an internal scupper flap?
97dauntless17
posted 06-01-2015 11:23 AM ET (US)
Yes, I'm talking about the one on the side. The scupper in the rear is mounted with screws on the outside. The ones on the side are thru hull fittings with no screws. |
97dauntless17
posted 06-01-2015 11:24 AM ET (US)
Oh, and yes, they have internal flaps. Thanks. |
97dauntless17
posted 06-08-2015 04:17 PM ET (US)
I was able to get the info I needed from BW. Thanks. |
masbama
posted 06-09-2015 07:29 PM ET (US)
Do you mind sharing what BW said? |
