| Author | Topic: Adding Lubricant to Gear Case |
| rodeohog |
I was changing the gear lubricant in my 2001 Evinrude 225-HP FICHT, and I was only able to [pump] about 16-ounces [of new lubricant into the gear case] when [lubricant] started flowing out of the top hole. What gives? Everything I look up says 34-ounces [of lubricant is contained in the gear case]. |
Did you follow the proper procedure? The procedure is demonstrated in a recorded presentation produced by the manufacturer and published at https://www.youtube.com/watch?v=YVlBtOzLYRE The presentation warns:
quote: This is probably "what gives." |
