posted 06-04-2015 02:25 AM ET (US) Hi, we recently purchased a 1981 15' whaler tiller steer. The hull is in excellent shape, but the wood could use some work. I don't think the wood has ever been removed, and I was wondering if it is better to try to refinish it in place - even though the end result won't be so good? Is there any downside removing the benches - will this cause the seats to loosen over time, or access for water to enter into the hull?
Any thoughts would be greatly appreciated!
Tom Hemphill
posted 06-04-2015 07:06 AM ET (US)
You should remove the wood if you will be varnishing it. There is no reason not to, and many reasons to do so. When reinstalling, seal the screw holes with a dab of marine caulk.
BeaconHill
posted 06-04-2015 12:18 PM ET (US)
Perfect - many thanks Tom!
PeteB88
posted 06-07-2015 09:20 PM ET (US)
Tons of previous posts on Continuous Wave about refinishing Whaler wood. I'd dig through them - you'll find great advice and procedures. Important! Always use highest quality marine grade finishes, caulks, supplies and tools - do not skimp on quality products. Always remove wood components from fiberglass boats for refinishing if you can. Don't worry about removing seats - I've done it plenty of times. Have fun with your project.
