posted 06-13-2015 04:59 PM ET (US)
I like Mercury Marine outboards. They are not always my first choice but I have two now due to them being on the transoms of boats I purchased.The fact that Mercury uses a mild steel pin on a part of an engine which is subject to spending a lot of time submerged in sea water indicates Mercury is not always thoughtful in its designs.
Perhaps the mild steel pin is the reason they attach a rather large sacrificial anode along the length of the pin about a half inch below it. Admittedly that anode on my engine is wasting and should be replaced. The anode is perhaps 25-percent wasted.
I've decided to replace the pin with a mild steel Mercury replacement and replace the anode at the same time. I'll keep a closer watch on the new pin and anode than I have done in the past.
If a new anode fails to to protect the pin I'll have a replacement fabricated out of 316 stainless steel.
If you have a similar engine keep a close watch on the pin.
