| Author | Topic: Remote Throttle Control Friction |
| tfrutchey |
My Mercury 90-HP [remote] throttle falls off while running, loosing RPM. In other words, it runs fine but I have to hold the throttle down to keep up the RPM. How do I adjust? |
| Phil T |
Remove the cover and look for a friction screw. |
Check the owner's manual or the installation manual or the service manual for guidance on how to adjust the friction for the remote control lever for the throttle. Usually these adjustments are accessible on the remote control throttle assembly without having to disassemble the mechanism. Often you can find exploded view diagrams of components like this on the manufacturer's website or on part vendor websites. Perhaps starting at https://www.mercurymarine.com/en/us/parts-and-accessories/parts-catalog will lead to a helpful resource. |
| tfrutchey |
Thanks, great place to start |
| dbrown |
If this is a newer style Mercury remote control (Binnacle), the adjustment must be made from under the dash. It is a 5/16 nut that is tightened to increase friction that will stop throttle creep. If you look to the right side of the control where the cutout is in the link I posted, you can see the nut that I am referring to. A half or full turn should do it. |
| dbrown |
I might add that this is another one of Mercury's intelligent ideas compared to other manufacturers simple way of accomplishing the same task. But the good news is, once it is set, you no longer need to access it. |
I think there is a bit of sarcasm there in dbrown's reply. If this were truly an example of Mercury's "intelligent design" the adjustment would have to be painted yellow, and there would be a QR code decal near it. You could then buy an $800 smart phone, get an $80 a month data service, and use the smart phone to decode the QR code. That would lead you to a website, where you could watch a recording showing how to make the adjustment--assuming you also had all that hardware and software to watch the recording. This does not seem to rise to that level of "intelligent design." |
