posted 06-12-2015 01:19 PM ET (US) I need to replace the plug wires on my 1994 OMC 90HP Turbo Jet. Accel makes a cut to length, do it yourself kit for auto plug wires. Would it be okay to use those? If so, they make a standard copper core set and a graphite conductor set for HEI systems - would either of these be okay or should I just track down and purchase OEM plug wires?
contender
posted 06-12-2015 05:12 PM ET (US)
I would go with factory stuff, Try Boats.net for parts and views of your engine...good luck
seahorse
posted 06-12-2015 07:47 PM ET (US)
You can buy lengths of Packard 440 metal-core plug wire off of a 100' roll at your dealer, then either reuse the ends if they are in good shape or buy new ones.
The other choice is to purchase the individual plug wire kits from Evinrude.
Either way, you get the correct type and size of wires.
